NO interior lights, at all
I have not even started this project on my new 96. I did not see anything in a search for cabin or interior lights. Any first steps may save me many hours.
I have no interior lights. no dashboard lighting. All the gages are working fine.
NO lights of any kind anywhere around the cabin.
The sunroof operates fine. The turn signals work fine, the exterior lighting is all fine.
The front seats move around with the switches at the base of each seat. the forward/rear is not working, but I will pull the seat to see the motor.
But its just weird that absolutely no lights. The radio and antenna work fine, the blower fans work fine.
Hoping there is a common problem, but it is dark in there.
The door locks do weird things, and the doorlock button is iffy, but at least there is power there.
Thank you so much!
tom
Thank you so much!
tom
See page 120
Editing
The Bdyy Processor Module is hot at all times by fuse # 3 or 4 in the trunk.
The interior lights as you enter the vehicle should come on and is controlled by the Security Lock Control Module with a door switch.
Have you tried a different door since you identified something out of wack with the locks ( a different door agreement switch for the SLCM system )
one of these 2 fuses may have been removed to silence the alarm during storage.
jagxj1996.pdf (jagrepair.com)
You may want to review this movie on the security section
Editing
swoop22
Nov 1, 2011 06:48 PM
