Oxygen sensor replacement
Old Jun 23, 2016 | 01:18 PM
Travis O'Gallagher's Avatar
Default Oxygen sensor replacement
So i have a check engine light on my 1996 xjr and i had it checked out to be the right downstream one. If i replace that one do i have to replace the other downstream one that is still working?
Travis O'Gallagher
Old Jun 23, 2016 | 08:38 PM
SD96XJ6L's Avatar
Travis O'Gallagher
You only need to replace the one . Just make sure you don't unplug the other one in the process and mix them up. Use a white grease pen or the like to keep track if you do unplug the other.
dartech
Apr 9, 2016 09:28 AM
Travis O'Gallagher
Apr 3, 2016 02:49 PM
vincent661983
Apr 2, 2016 12:59 PM
xkeots
Mar 31, 2016 02:03 AM
Dean Kitching
Mar 30, 2016 02:53 PM
