P0300 and P1313 codes...please assist!
Old Sep 10, 2013 | 11:41 AM
Dan Bennett's Avatar
Default P0300 and P1313 codes...please assist!
OK, so having a code reader permantently attached to my car and an ipad nearby at all times has proven to be helpful.....
With these codes and, with them, a rough idle, can I expect in most cases that replacing my coils (I'll have a set of 6 here today hopefully) and, for good measure, taking my iridium plugs and swapping with Champion coppers take care of the issue?
Could it be other things? I do have a new CKPS on-route too just to have since I am told that they will go bad but would that be a good thing to replace now just while I'm under the hood or possibly exhibit these codes if bad?
Just trying to cover all bases and understand the car.
Thanks!
Old Sep 10, 2013 | 03:41 PM
basco1987's Avatar
Hello Dan,
P1313 = Misfire Rate Catalyst Damage Fault - Bank 1.
Have a look at this thread, maybe it will help:
http://www.jaguarforums.com/forum/x-...d-start-10619/
Cheers!
Harald
Old Sep 11, 2013 | 07:57 AM
So a vacuum leak most likely? I won't have the coils in until the weekend at which time I was just going to replace them anyhow and keep ahold of the old as a last resort since I also wanted to replace the plugs anyhow.
I have an appointment tomorrow already set to do shocks and a-frame bushes and I hope I can convince them to fit in a vacuum test in that same time period..... not sure how available parts are same-day if needed though...
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
reb1999
Sep 26, 2015 08:41 AM
10 XF Premium
Sep 20, 2015 12:51 PM
