p1193 & p0121
Old Oct 13, 2010 | 01:07 PM
bigreguk's Avatar
Default p1193 & p0121
hey guys,
p1193 - manufactor. controlled fuel and air mettering
p0121 - throttle/pedal senor A circuit range performance
I just replaced the TPS, so is it a bad sensor or is the p1193 triggering it to come back on? Is the p1193 a mass air flow sensor? i cleaned it out about a month ago.
Would really appreciate some input on this
thanks,
Reggie
Old Oct 13, 2010 | 10:06 PM
sparkenzap's Avatar
year model???
for 96-97 the 1193 code is the downstream lambda heater circuit
for 121-Intake air or exhaust restricted
Extreme high altitude operation
Intermittent / incorrect , but undetected; TPS,
engine speed, IATS, MAFS or IACV signals.
So it means the tps position may be wrong compared to the temperature the mass air or an idle valve- it sounds like a catch all.
No offence, but I would check the plugs you took off replacing the tps and issc
Old Oct 14, 2010 | 08:20 AM
bigreguk's Avatar
its a 97 4.0
So 1193 is a 02 sensor?
After getting off the highway, the car sometimes have an idle around 1500, then will slowly go back to normal as i cruise around at city speeds. This problem is caused by the 0121 correct?
thanks for the reply
Old Oct 14, 2010 | 11:52 AM
sparkenzap's Avatar
Is your car a US model or ROW?
The codes I quoted are correct for a '97.
The problem could be any number of things from those codes. You say you put in a new TPS. I assume you did not do the setup on it, since it takes the dealer type software. What is the max and min voltages reported for the TPS?
Note that the code says Lambda HEATER circuit. That might or might not be the lambda itself. If that code returns after reset, I would go after it before I worried about the P121 code, since there is almost nothing else that should affect the heater circuit except ecu output, wiring, connectors or O2 sensor.
Good luck!
Old Oct 14, 2010 | 12:09 PM
bigreguk's Avatar
its a us car.
You say setup on the tps...what do i need to do for a setup on it?
You seem to know quite a lot what your talking about. Excuse me if i come across ignorant, but what is the lambda?
Old Oct 14, 2010 | 08:38 PM
sparkenzap's Avatar
Sorry- I was not trying to "jargon" you. The oxygen sensor is also called a "lambda" sensor. There are two setups done on a XJ6 engine with dealer software. One is the "Lambda resequence" which assures the left and right sensors are connected to the proper sockets, since they are not marked left and right. Another setup sets the zero and span of the TPS since ther are no slots on the mounting as in other cars.
nonfinito
Nov 20, 2015 09:57 AM
Sq-STR
Aug 27, 2015 07:27 AM
Vbolden1
Aug 7, 2015 09:09 AM
larryjk
Nov 11, 2014 04:14 PM
italcarnut
Sep 2, 2014 07:45 PM
