Piston Rings -- Engine (AJ16) rebuild
Old Sep 4, 2024 | 02:18 PM
smartobject's Avatar
Default Piston Rings -- Engine (AJ16) rebuild
So as I am in cleaning and building mode now -- I am searching for rings -- 90mm diameter but the thickness I'm not sure on yet.
These have very tight clearances (almost zero) to the piston grooves.
Do we have any ideas on where these may be available.?
Old Sep 5, 2024 | 12:11 AM
AnttiM's Avatar
https://www.ebay.co.uk/itm/225689130941 ?
note: I did not check in details if these are actually correct of not
or maybe these guys
https://www.enginerebuilding.eu/jagu...jr-aj16sc.html
could have them available , would not cost anything to ask?
Old Sep 5, 2024 | 10:11 AM
Yes. Thank you. This gives me hope to press on!
Old Oct 27, 2024 | 06:46 AM
someguywithajag's Avatar
or maybe these guys
Wish I had seen this post before
The eBay ones will not work for the X300. The dimensions don't match nor does the ring design
Old Oct 28, 2024 | 04:21 PM
JezuzNoChill's Avatar
Try this.
https://www.totalseal.com/find-a-ring
Old Oct 30, 2024 | 12:11 AM
Originally Posted by JezuzNoChill
I contacted these guys out of curiosity. They will sell you the correct-sized ones but they don't do the Napier-style cut on the second ring. They say that the profile of their second ring will give the same performance as the original ring. I already have a set from Grant piston rings so I didn't order any but nice to know that this is another option as well
Old Oct 31, 2024 | 03:20 AM
Note: these would be moly coated. whereas the Grant ones are phosphate coated. I believe moly coated rings require more cylinder prep
Old Nov 8, 2024 | 12:14 AM
Shop High Performance Piston Rings Online - Deves.com
Call these guys with the dimensions. They were the old suppliers of piston rings to Moss Motors. The set they sell will work. Albeit the ring profiles will not match
If you want the original ring profiles, order the second ring from them. And the first and the oil control ring from Grant piston rings
Both in cast iron (although Grant will do chrome coated ones like the original)
sanchez
Aug 30, 2024 08:36 AM
Wildcat_nl
Oct 18, 2022 09:24 AM
calvindoesntknow
Dec 18, 2015 08:02 AM
TC Johnson
Apr 26, 2015 03:23 PM
monicagregory
Jun 21, 2013 11:45 PM
