Popping Noise When Brake Peddle Depressed
Old Jan 22, 2015 | 08:58 PM
azjagguy's Avatar
Default Popping Noise When Brake Peddle Depressed
Hi -
New to the forum, and new to Jags. Have a 1996 XJ6 VDP and just replaced front shocks. Now, I have a popping noise that occurs when I depress the brake peddle. It happens only once, and only when I depress the peddle, but it happens every time. I can be moving or in park, and the popping noise will happen. It sounds like its coming from the glove box and actually sounds just like a pebble hitting the windshield. That's actually what I thought was happening when I first noticed the sound. Has anyone experienced this before?
Old Jan 22, 2015 | 09:36 PM
notthemaniusedtobe's Avatar
There's a locking mechanism on the gearshift that "pops" when you press the brake pedal. It makes a small noise as it's releasing the lock on the shifter. Without pressing the brake pedal you can't move the shifter out of park, and the noise you hear is when that mechanism releasing the level. That'll also be why it vaguely sounds like it's coming from the direction of the glove box.
I've had my Jag for 6 years and it's alway done this, never had any issues with it, I just kind of assumed it was normal. Some of the more experienced members may clarify if it's a problem.
Hope that helps.
Old Jan 23, 2015 | 05:38 AM
sogood's Avatar
Hope that helps.
The gearshift lock mechanism that you talk about, is only used when the car is in park, preventing a gear from being selected, unless the brake pedal is depressed. The OP seems to have this popping noise at all times, including when driving. If the gearshift solenoid activates when driving, there might be a fault on the brake pedal switch (in behind the actual brake pedal).
Does the shift lock solenoid operate when you press the brake pedal? It should make an audible "click" rather than a "pop" and the sound will come from below the ski slope beside the gear shift, which is where it's located.
Otherwise, I would have a good look see down around the brake calipers etc. just to ensure that nothing was disturbed when your shocks were changed, as the two may well be related. Ensure that the calipers, dust shields etc. are all tight and snug.
Just a thought.
Old Jan 23, 2015 | 08:52 AM
azjagguy's Avatar
Default Thanks!
Thanks John and Sogood. John, this popping noise does happen while driving as well, so I don't think it's the locking mechanism you referred to, but I appreciate the info, since I didn't know that. Sogood, I haven't noticed the "click" to which you refer, so I'll check on that tonight. And I had planned on checking the brakes this week end.
Old Jan 23, 2015 | 02:48 PM
I missed the part about happening all the time, my bad.
Old Jan 24, 2015 | 04:16 AM
'just replaced front shocks' - was the noise happening before this is or has it started since the replacement? If it has only started following the replacement, check over all fastenings that were disturbed.
The gearshift interlock makes a soft click and it's right next to the shift lever but you say the noise is coming from the right and forwards of that.
My first thought was a failed metalastik Vee Mount on the front suspension allowing metal to metal contact under braking but as the noise happens both moving and stationary, you should be able to discount this.
You're 'lucky' it happens in Park as this will make isolating the source easier. Jack up the vehicle and remove the right hand front wheel. Have an assistant press the brake pedal so you can see the action at the caliper. Check for sticking pistons or deforming flexi hose under pressure. If all looks good, repeat for the other side - noise location is notoriously difficult from the driver's seat!
Old Jan 25, 2015 | 02:31 PM
azjagguy's Avatar
Default Re: Popping Noise
Hi Graham -
Thanks for the suggestion. The noise wasn't happening prior to shock replacement, so I will check the fastenings and removing the wheel as you suggested. I had planned on doing just that this week end, but time has gotten away from me, so I will shoot for next week end.
Razor
Aug 28, 2019 08:34 PM
PMKimpton
Aug 3, 2019 08:22 PM
James007
Oct 3, 2015 03:29 PM
sawduster
Sep 11, 2015 10:02 PM
