Pushing car to work this morning...
Old Feb 21, 2014 | 09:20 AM
heuster's Avatar
Default Pushing car to work this morning...
Okay here is the scenario...
Stopped at a red light and I accelerated when it turned green. About 1/2 way through the intersection the car died. With great presence of mind I flipped on the hazards, hopped out and kept her moving through the intersection and over to the right. Some dude even pulled over and helped push the rest of the way to the shoulder(must have been because it was a "Jag"). Got to the shoulder and stopped, jumped in, turned the key and she started right up and I drove the rest of the way to work.
So - now we start the guessing game. My guess is it's a failing fuel pump. There has been a distinct "whine" and I can't tell where it's coming from...but it sounds like fuel pump whining. Every so often it will quickly change pitch and return to it's former whining glory. Fuel filter? Not likely, but would be really nice if that's all it was.
Thanks all for your input!
Old Feb 21, 2014 | 01:42 PM
Suede's Avatar
I think you're on the right track. I'd change the fuel filter first to rule out the cheapest possible culprit, then check the fuel pump relay, a common troublespot.
Old Feb 21, 2014 | 01:48 PM
heuster's Avatar
Does this car have 2 fuel pumps?
Old Feb 21, 2014 | 02:51 PM
RJ237's Avatar
Just one pump
Old Feb 22, 2014 | 06:25 AM
SleekJag12's Avatar
But two relays! You need good relays in the RH rear heelboard main bus, and the fuel pump relay in the trunk fuse box, second from right with the green base.
I just posted in the other thread: Old spark plugs cause totally random stalling. Don't ask me how I know this.
Old Feb 22, 2014 | 06:27 AM
SleekJag12's Avatar
That wasn't me that helped push your car, but what a way to meet other forum members!!
BrentGardner
29
Dec 16, 2024 12:13 AM
johnnie ryall
Oct 19, 2015 09:44 PM
97xj6lucy
Sep 3, 2015 07:44 AM
Kristian_TT
Aug 28, 2015 02:32 AM
