Question about relay colors
Old Dec 25, 2013 | 07:32 PM
zathras's Avatar
Default Question about relay colors
Hi all
I just discovered my car has heated mirrors. I found this out when I touched the mirror and almost burned my fingers off. No the rear demister is not switched on, the heater appears to be running constantly so I removed the fuse for now.
I checked the manual and it appears to suggest I am supposed to have a violet relay in the rear socket closest to the fuse box behind the rh heel board. Well mine is blue. Do you guys think that it might have fried the relay because it's the wrong one? Would I be advised to replace it with a violet relay and see if that fixes it? If not, I have never had heated mirrors so it's not the end of the world if they stay disconnected but it would be nice to fix it.
Chris in New Zealand.
Old Dec 26, 2013 | 07:06 AM
AllanG's Avatar
What year is your car? My wiring diagram calls for a black relay.
Old Dec 27, 2013 | 02:54 AM
zathras's Avatar
Hi
Mine is a 97 XJ6L ex-Singapore if that makes any difference
Old Dec 27, 2013 | 07:33 AM
AllanG's Avatar
Hmmm, just looking at the relay layout for the MY97 and it shows the relay should be black with a blue stripe?
97 relays.pdf
Old Dec 27, 2013 | 08:58 PM
zathras's Avatar
Ok well that is the relay I have already so that can't be it. Thanks for your help!
way2far
Aug 31, 2022 09:26 AM
redrover41
23
Sep 25, 2015 01:33 PM
leep123
Sep 12, 2015 06:53 PM
jaguarbill
Sep 5, 2015 11:43 AM
XJsc-guy
Sep 2, 2015 11:43 AM
