Radio issue
Old Jul 11, 2020 | 04:50 AM
Craig Mcwhinnie's Avatar
Default Radio issue
Hi everyone I have a 1997 xj executive and recently the radio has stopped working its the standard radio when you turn the key absolutely no lights on the radio at all the aerial rises when the engine is started but nothing on the radio any help would be appreciated thanks
Old Jul 11, 2020 | 06:57 AM
Parker 2's Avatar
With the executive model you most likely have the standard radio option that does not include a separate power amplifier for the speakers
Fuse X and Y
See page 160
http://www.jagrepair.com/images/AutoRepairPhotos/jagxj1997.pdf
The on off switch is called a encoder of a certain shaft size
You can try to clean it or just replace it
Old Jul 11, 2020 | 07:34 AM
Thanks do you just access that from behind the Radio or can you get it without taking the radio out
Old Jul 11, 2020 | 01:25 PM
Parker 2's Avatar
There are tiny screws om the units side box enclosure so the unit must come out
With the unit in your hands the front plastic panel must come off to get to the encoder
See this link
https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/radio-replacement-xjr6-x300-1996-a-204735/
Old Aug 9, 2020 | 08:46 PM
afterburner1's Avatar
It would help if you identify the size of the hole the radio fits in: 1din is 2" x 7"
Old Aug 9, 2020 | 11:44 PM
Parker 2's Avatar
Just say no to original stereo head unit replacement
Old Aug 13, 2020 | 01:11 AM
SleekJag12's Avatar
It is 1 din with a funny curved face plate. If it helps.
Now my radio digital display panel illumination has gone out too. I'm doing my best to say no to original head unit replacement.
I had to use search to find out how to re-illuminate the panel but came up empty.
But I'm not going to ask Parker how to do it because of pride.
Old Aug 13, 2020 | 10:55 AM
Parker 2's Avatar
Someone recently came up with a easy solution to the radio button lights
After a while I might be able to find it again
Old Aug 13, 2020 | 11:57 AM
katar83's Avatar
Scroll down a little on the first page, you'll get there
https://www.jaguarforums.com/forum/x...repair-229403/
Old Aug 13, 2020 | 10:11 PM
SleekJag12's Avatar
Ok thanks again Katar, I remember seeing that. At the time I assumed it was for the button backlights. I have button backlighting, but no display backlighting. So I will take it apart and see if I can replace that resistor for the panel lighting. I'll let you know how it goes.
Tbilisi79
Nov 23, 2018 08:10 PM
93xjs6cyl
Apr 27, 2017 10:41 PM
dougsjag
Nov 13, 2014 03:50 PM
