Rattle from back
Old Apr 28, 2020 | 08:13 AM
nakuttaja's Avatar
Default Rattle from back
Hi. My X300/-94 gives some rattle/noise from the back of the car when driving over bumps/holes in a road. Earlier the same came also from the front, but it (worn rubber parts supporting the cooler) is fixed now. I also tightened the spare tyre, which was also loose, but the sound is still there. Could the noise be made by a loose gasoline tank? I still have original shock absorbers, but as there are no visible leaks and the car has only 93 000 km road behind, I have not changed them yet.
All ideas wellcome.
Old Apr 28, 2020 | 11:25 AM
xalty's Avatar
Try adjusting parking brake 2 clicks up, linkage is known to rattle. When there’s a knock in the back usually it’s the bushings on the shocks themselves.
Old Apr 29, 2020 | 11:43 AM
nakuttaja's Avatar
Thanks for the tip. I tried the parking brake,but unfortunately it did not help for this noise. So it’s most probably the shocks.
tietjens
Oct 9, 2024 07:11 PM
Jon89
Jul 2, 2021 02:10 AM
Stu Jags
Aug 22, 2019 02:51 PM
greygoose
May 9, 2013 07:36 PM
Alwann
Jun 23, 2008 08:22 AM
