Rear air suspension
Old Mar 29, 2026 | 04:58 AM
Nedvedgoal2024's Avatar
Default Rear air suspension
Hi guys,
I was hoping for some tips on where to start on my 2004 xj6 rear air suspension ride height.
The rear passenger ride height is "out of scope" to calibrate on SDD as its if I remember correctly at 455mm so the scanner won't allow me to bring into line with the rest of the car.
could this be the strut as i have manually lowered it to see if its still working, raised it with the scanner and this worked with out issue, but the problem im having is when it raises it to goes to the 455mm and is out of scope?!?!
I have read about "tricking" the ride height sensors into thinking there higher than they are so they automatically lower but cannot find any further information on this.
So if anyone has any experience with this sort of thing your advice would be very welcome.
Thanks as always
Mark
Old Mar 29, 2026 | 08:00 AM
Parker 7's Avatar
This section is for the 94.5 to 97 X300 ( inline 6 or V - 12 ) , no air suspension , same chassis
Try reposting here
XJ XJ8 / XJR ( X308 ) - Jaguar Forums - Jaguar Enthusiasts Forum
You may actually have a X350 / 358 ( aluminum body shell of a 350 )
Tommyokeeffe
May 16, 2024 10:37 PM
MS333
Aug 22, 2023 07:31 AM
Branbeezy
Mar 18, 2016 07:48 PM
Frankleroy
Jan 30, 2015 08:19 PM
SebastianV
Jun 13, 2013 08:45 AM
