Rear Passenger window Q
Old Jun 10, 2010 | 07:39 AM
trinitysj's Avatar
Default Rear Passenger window Q
My rear passenger window will not roll down. Could it be a regulator, or switch?
Old Jun 10, 2010 | 06:17 PM
bhmaxjag's Avatar
It could be either one of those things. Pull the door panel off and use a test light to check to see if you are getting power down to the regulator motor when operating the switch. If you are not getting the power, then suspect the switch or wiring. If you are getting power and the motor is not operating, then you need a new regulator motor.
This is all assuming you have already checked fuses (though I am not positive if we have separate fuses for each window on our cars as I have never had an issue with mine that warranted checking).
Old Jun 10, 2010 | 08:19 PM
trinitysj's Avatar
Thanks for the pointers. I will check all of that and get back to you.
99xk8guy
Sep 29, 2025 10:51 PM
H20boy
Dec 24, 2024 03:23 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
