Removing overhead console x300
Old Feb 21, 2015 | 05:04 PM
IreallywantaJag's Avatar
Default Removing overhead console x300
How do I remove the overhead console from my 97 xjr? I've removed the screw in sunglasses compartment but am scared to pull on it in fear of breaking any plastic clips???? Any advice would be greatly appreciated.
Old Feb 21, 2015 | 05:41 PM
retromotors's Avatar
I googled some pics of (supposedly) the console for your car. It appears to be the same as my '98 XJ8. If so, here's the scoop:
One large plastic "screw" in the sunglass holder.
Then pull straight back on the console, parallel to the roof. It's held by two fairly large sheet metal clips up front, nothing fragile or easily broken.
Good luck!
Retro
Old Feb 21, 2015 | 05:45 PM
jagent's Avatar
I had mine off some time ago. After turning the screw (quarter turn if memory serves?) apply gentle pressure and pull back on the unit, then it should come away. There's an multi-connector sitting behind, disconnect it to remove completely. I seem to recall the retaining clips are metal and I didn't feel they would break easily.
Old Feb 24, 2015 | 01:00 PM
mgb4tim's Avatar
It's tight, drop the front just a little, and pull towards the back. Getting it back onto the front hooks from the roof during installation is a bit of a treat.
aholbro1
Dec 29, 2024 06:46 PM
Forcedair1
Feb 19, 2020 01:51 PM
eurotire
Sep 18, 2015 07:27 AM
280zx-turbo
Sep 10, 2015 06:29 AM
AL NZ
Sep 4, 2015 08:39 PM
