Retrofitting electric & heated seats to X300
Old May 10, 2026 | 09:51 AM
tobywood13's Avatar
Default Retrofitting electric & heated seats to X300
Hi all, my ‘96 XJ6 has manual, non heated seats. I’ve seen a parts car advertised which has heated seats in the right colour, so I’d be tempted to swap those in as I like to try and retrofit optional extras to all my cars.
If I buy the seats and the control panel switches, are these plug and play with existing wiring or will I need to get any additional electrical components too?
Second question, can the heating elements be added to my manual seats? I prefer manually adjustable seats, so if I can keep these as they are that would be preferable.
Thanks!
Old May 13, 2026 | 11:35 AM
katar83's Avatar
Apart from seat and switched, You'd just need the extra loom cable under seat(plug hidden under carpet), manual seats either don't have it or have a thin version of that cable. You'd also need to make sure the seats have seat modules(doesn't matter if memory or non memory ones, both will work).
I fitted heated passenger seat for Mrs in my car.
Old May 13, 2026 | 11:46 AM
tobywood13's Avatar
Thanks for that info, very useful. Will my car have a plug under the carpet ready to connect to the loom you mentioned? And where are the seat modules located?
Old May 13, 2026 | 02:13 PM
katar83's Avatar
You're going to have to fish it from that hole, the plug is there under carpet, also there is a ground cable bolted to the tunnel.
Seat modules are under the seat, attached to the seat itself.
Old May 14, 2026 | 05:28 AM
tobywood13's Avatar
Brilliant, thanks for your help!
Atipical
Jul 2, 2024 01:35 PM
wrd0225
Apr 25, 2017 03:16 PM
james5281
Mar 5, 2015 02:31 AM
FinAdvisor
Dec 4, 2010 07:21 PM
