rough idle when ac is on
Old Jul 14, 2012 | 06:56 PM
JagfanNYC's Avatar
Default rough idle when ac is on
So last week, I got my ac recharged. It works great nice and cold. But my problem is whenever I come to an idle either in park or in drive the car will have a rough idle. The battery gauge will go down between 12-13 but once I accelerate its normal again. Could it be the iac? serp belt?
Old Jul 15, 2012 | 04:56 AM
My suggestion would be the ICV (idle control valve) is lazy to keep track of what is required. The compressor is sensed as "load" and the ICV must compensate for that.
Being as how you are in the States, your car has an EGR system, that I have read reeks havoc with idle until the "valve" is cleaned??. We dont have that system, so I have no hands on with it.
The notorious "black goo" inside the throttle body, and around the throttle disc also gives grief to stable idle.
Old Jul 15, 2012 | 12:12 PM
JagfanNYC's Avatar
I will check into that thanks
Old Jul 16, 2012 | 09:19 AM
OttawaX300's Avatar
I had the same issue. I had previously got my car to the point that the idle was super smooth. A few weeks ago the idle became quite rough and the steering wheel would vibrate at idle. Then the ac compressor died and the idle was super smooth again. New compressor is being installed today.
Old Jul 17, 2012 | 09:53 AM
OttawaX300's Avatar
Just got the car back after the new compressor install. The rough idle that was there immediately prior to the failure of the old compressor has not returned.
Hopefully the OP's problem is not a dying compressor.
bdboyle
Sep 16, 2019 05:58 PM
workworkwork
Oct 23, 2015 10:26 AM
tomkilner
Oct 9, 2015 07:10 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
