Seat Memory 1995 XJ6
Old Oct 12, 2017 | 09:10 PM
benzjag's Avatar
Default Seat Memory 1995 XJ6
I'm trying to get the seat memory to work on a 95 XJ6. I removed the seat memory module out of my 97 XJ6 (which works perfectly) & put it into the 95. I thought I had found the problem because the memory worked perfectly in the 95 (with the 97 memory module) and using the stored seat postions from the 97. The problem came when I tried to reprogram it. I pressed the memory button. It lights up and chirps to confirm the system has accepted the new seat positions BUT when pressing the "1" , the seat does nothing. If I press "2" or "3" the seat moves fine from the 97 stored memory. By working in 2 or 3 perfectly, I assume the seat poidentors (sp) are fine. What is the problem when the system confirms the new memory but the seat is "dead"?
I have spent hours researching but no answers!
Richard
Old Oct 12, 2017 | 10:03 PM
Lady Penelope's Avatar
You may may have installed it with power on or touched the pins with static electricity in your finger tips . Try just removing the positive only cable to the battery 1 minute and see if the ECU resets to zero state . If not then try a Jaguar " Hard Reset "
Does anyone know the reset through touching buttons on the radio control head ?
