Hi, I am also contemplating an xjr-6 engine into my 85 xjs 3.6 manual. I have a complete 1995 xjr automatic(uk spec security system) as a doner vehicle. My question is regarding the security built into the ecm. Can this be removed/disabled as my xjs does not have any immobilizer system. If not then which modules are involved in the security system that i would need to transfer from the xjr to the xjs. Also would an ids system reflash the ecm and change the configuration to make the ecm think it was a manual gearbox xjr? Sorry if this post offends anyone as this is my first post and im not sure of the rules of engagement or if i should start a fresh thread on this amazing forum. Kind regards Gary
sparkenzap
close
- Join DateNov 2007
- Locationatlanta ga
Liked:1,068 Times in 870 Posts
Gary
Welcome. They do like you to stop by the new member site and Tell us about yourself.
You need to contact andy who uses the handle " xjrengineer" for the most definitive answers on your questions, I believe. You might pm him.
