Servo vacuum pipe
Old Nov 20, 2013 | 11:41 AM
drmike's Avatar
Default Servo vacuum pipe
Am I right that there is a pipe that runs from the top of the inlet manifold to the servo and looks like some sort of push fit?
If so should it be loose, mine is?
Mike
Old Nov 21, 2013 | 08:10 AM
EZDriver's Avatar
Mike
You got me curious. So I just went out and looked at my 95. And yes the connection at the manifold is loose and appears to be a push fit. At the brake servo it seems a lot firmer. I don't like even slightly loose fittings on the intake side of the engine. I think I might smear a little of the black high tempt silicone around it to cut down on any leakage.
Keep in touch.
Old Nov 21, 2013 | 08:21 AM
drmike's Avatar
Sounds the same as mine then. Perhaps the vacuum in the manifold pulls the fit tight?
Old Nov 21, 2013 | 08:25 AM
Doug's Avatar
You guys just jogged my memory.
That push-fitting broke on my XJR. The pipe wouldn't stay in place. Naturally the car ran terribly. I patched it together with JB Weld with every intention of properly repairing it "in a few days".
That was 3 or 4 years ago
Might as well leave it alone at this point, I reckon.
Old Nov 21, 2013 | 08:28 AM
drmike's Avatar
It seems odd that it's a loose fit though. Mercs are the same apparently, a similar push fit and they do come loose.
I was thinking of some JB weld type stuff, I just wouldn't want anything to be sucked in
Old Mar 2, 2014 | 12:06 AM
AllanG's Avatar
How exactly does one get this pipe off the manifold fitting? The fitting on my car is broken and I have a new one but can't seem to get the pipe off! I've tried pushing it in to release the clamps and then pulling it out but it will not budge. Someone must have tried fixing it at some point as they slathered it in RTV.
Also once the pipe is off, is there a trick to getting the cartridge out other than getting medieval with it? It seems to be pressed into the manifold.
tomkilner
Oct 9, 2015 07:10 AM
NathanDD6
Oct 6, 2015 11:20 AM
Johncy2000
Oct 2, 2015 01:05 AM
baskervillema
Oct 1, 2015 06:43 PM
