speedo abs track fail
Old Mar 23, 2014 | 03:08 AM
Mfieldpreecher's Avatar
Default speedo abs track fail
Speedo quit working on 96 xjr. Get abs and track fail light too. Thinking the wire from tranny might a problem. There evidently had been a lot of movement as the mount needed replaced. Anyhow, will OBD I scanner tell me anything? How do I find where to begin if there is not obvious damage at the tranny wire? Also had brakes done while at shop (pads and rotors all around).
Old Mar 23, 2014 | 06:48 AM
RJ237's Avatar
The obd scanner will not help, these are Jaguar specific codes. I believe the left rear wheel sensor provides input for the speedo, hopefully some one will correct if I'm wrong. Look for a break in the cable, but it may not be obvious from the outside.
Old Mar 23, 2014 | 07:21 AM
Doug's Avatar
I agree with RJ. Begin with checking the left rear wheel speed sensor and wires.
Old Mar 23, 2014 | 04:03 PM
theJPster's Avatar
According to the wiring diagram, vehicle speed is on a Green/Black (GK) wire which comes out of the ABS control unit. Might be worth a look there if the sensor checks out.
GGabriel
Nov 22, 2018 03:53 AM
RollaJones
Sep 27, 2015 03:31 PM
LnrB
Sep 25, 2015 08:58 AM
mrplow58
Sep 24, 2015 08:05 PM
pocketrocket
Sep 3, 2015 07:44 PM
