Split a belt
Got my car fitted with four new UJs and two new calipers ready for its MOT. My brother gave the throttle a blip before it came off the ramp and it ripped half the alternator belt.
Now I thought the belt was a touch loose as it did sometimes still squeal, but popping a couple of cords suggests it was over tight. Fingers crossed it isn't actually the damper squealling. Or a duff pump/alternator reluctant to turn.
It was a cheap belt. Are they known to give way?
They can seperate. Usually age related more than $ quality.
Too tight will generally cause issues with rotating bearings, etc, and eventually the belt will fail.
Too loose and they will not drive. Unlike a "V" belt that can still provide some drive whilst being very loose, these multi-rib are far less forgiving.
Mis-alignment of the pullies is a big cause of seperating, usually an idler/guide pulley with a bearing going bad, and alignment is compromised.
Heat is a killer to the fabric of the belts. Due to the tentions they run at, they also run quite a bit hotter than the older "V".
New wheel bearings and diff I think. Just put new bloody hub nuts on too.
Why would the half shaft play be the cause? If I understood correctly, your brother blipped the throttle while in neutral on a ramp?
Ah, no, sorry.
We replaced the UJs in the half shaft to cure the play and rumbling.
Quite unrelated, it popped a belt going to the MOT.
We replaced the belt and got it to another MOT a few days later, when...
It failed on half shaft play.
X308XJR
May 20, 2019 06:50 PM
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
Sep 28, 2015 07:29 PM
