Starting, what the h...?
Old Yesterday | 11:09 AM
No Quarter's Avatar
Default Starting, what the h...?
Recently purchased, always ran fine. Today I started it, it was like it was running on 2-3 cylinders only, barely able to stay alive. Turned it off, started, and it ran perfectly. And has run perfectly since (5 starts). Any ideas for this on/off problem?
Old Yesterday | 12:55 PM
No Quarter's Avatar
I guess my question is, what are the touchpoints that control only half the cylinders? Relays etc?
Old Today | 01:12 AM
Parker 7's Avatar
The 1 to 6 cylinders get the fuel and then the separate wires for the ignition both from a source , one source for each , these sources have splices and a splice can be bad
So background , the ignition " power " to the coils " sitting " on them present at all times waiting for an ECU provided ground to have current run through the devices to do their thing , either make the coil energize and zip the spark plug or as a totally separate wire system open the fuel injectors
So the splices located on top of engine under the 4 inch wide Jaguar labeled cover
The power for the coils starts at X
The power for the injectors start at Y
Editing
This diagram for the supercharged engine is the exact same for the normally aspirated except SC does not have a Z device ( EGR to help pass emissions ), only difference is how to regulate the engine with different paramotors like compression ratio ( supercharged shorter stoke on the crankshaft throws ) so the ECU has different data maps determining how much fuel to inject
Editing
Old Today | 01:25 AM
Parker 7's Avatar
I tried to get editing done but computer glitch so failed but will try again in morning , sleep priorities as father just died
Old Today | 01:38 AM
Parker 7's Avatar
The wiring guide is not physically correct but is functionally correct as that many wires should not be placed in a single splice for general practice reasons and how much space you have to place a giant splice , so that single splice item becomes 3 or 4
From reading others these splices rarely go bad but doesn't mean they can't
Old Today | 01:44 AM
Parker 7's Avatar
The blue wires same thing for the coils ( fuse # 12 right engine bay fuse box ) , gotta go and focus on my night meds accomplished and get some sleep to do tomorrow
But the writing of this reply and it's technical aspect does relax me
oxendine
Sep 14, 2022 05:15 PM
stephenniz
May 16, 2022 10:24 AM
Mark Bialzik
21
Jul 1, 2021 05:57 PM
chazaroo
Aug 17, 2012 11:39 AM
