Sticking in Park once in a while
Old Oct 24, 2010 | 07:52 PM
Simprof's Avatar
Default Sticking in Park once in a while
My 1997 XJR will not start from time to time when the car is in Park, it will if I get it into Neutral but sometime it will not move out of park. Will this be linkage or something else going on.
Old Oct 26, 2010 | 04:15 PM
sogood's Avatar
It sounds like a simple electrical fix. On my xj6, park wont disengage unless the footbrake is engaged (as a safety feature) nor will it attempt to start unless it is in Park or Neutral, thanks to a "Start inhibitor switch" which should be located beneath the gear shift gate/cover. A little look around should reveal the problem, perhaps the switch has come loose, or an electrical connection has. Check and clean any connectors you might find under there. Hope this helps.
Old Oct 27, 2010 | 09:03 AM
Simprof's Avatar
I'll ley you know soggod once I have the time to check it out and thanks for the input..
n2audio
19
Jan 20, 2025 09:35 PM
vwbusbits
Oct 13, 2015 03:43 AM
DFW
Oct 1, 2015 07:22 PM
JTC3400
Sep 29, 2015 05:03 PM
Ragn0r
Sep 29, 2015 10:38 AM
