suspicious water pump
Old Mar 8, 2010 | 09:16 PM
panchostatus's Avatar
Unhappy suspicious water pump
1996 XJ6 4.0,
I pulled her into the garage and smelled coolant.
After some sniffing around I found a trail of coolant coming from the bottom of the water pump.
I just put this water pump on & all new coolant hoses when I changed my head gasket, so this pump doesn't even have 5k miles on it yet!
Usually when I encounter an issue like this, I assume the pump needs to be replaced. But, given it's recent replacement, is there anything else it could be?
Bad gasket? Installation error?
I torqued that bottom bolt down some more in hopes that maybe I didn't tighten it enough during installation, and I'll see if it leaks anymore.
-pancho
Old Mar 9, 2010 | 01:26 AM
These pumps have the "tell tale" hole at the top, easily seen from the top, obviously, and if coolant is NOT leaking out of that hole, then the seal is more than likely OK.
I reckon you got a bad gasket, or hose connection.
Old Mar 16, 2010 | 02:34 PM
as a follow-up,
I took the pump off, fitted it with new grey RTV silicone for a gasket, and reassembled.
reassembly was such a fight, that I'd bet money I messed up how it seated.
the leak has been reduced to a mere drip every few days.
so better, but not completely fixed.
I'm thinking I'll just live with it and add coolant every few months
Old Mar 16, 2010 | 07:27 PM
sparkenzap's Avatar
sure looks top me like you might have a shaft leak-
Old Mar 17, 2010 | 02:26 PM
that did come to mind also, but I was hoping a better seal around it would cure it.
it is a reman pump, maybe a not so good rebuilt pump?
Old Mar 17, 2010 | 03:16 PM
sparkenzap's Avatar
Well, many rebuilders might have less QC than main line manufacturers.
Wahooesprit
Dec 23, 2019 02:01 PM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
ksjaguar
Nov 3, 2015 10:14 AM
picard
Oct 12, 2015 11:56 AM
