Switch for antenna
Old Sep 14, 2012 | 11:15 AM
bliving7's Avatar
Default Switch for antenna
Hey All.
I have a 1995 basic XJ6 that I bought new and now has 220K miles. I also just bought a 1996 VDP with 98,500 miles.
I put a switch on the antenna on the '95 so that the antenna would not cycle except when I was listening to the radio. I cut the green/black wire on the main radio harness at the back of the radio. No problem.
So I wanted to do the same thing with the '96. But when I did the same procedure the system would not power up without the antenna switch closed. This car has the premium system with the HK amp in the trunk. This makes no sense to me.
How I'm thinking of putting the antenna on a separate switched circuit.
Any ideas?
Thanks.
bliving7
Old Sep 21, 2012 | 06:07 PM
bliving7's Avatar
Default new info
Hey All,
I'm adding to my original question. I looked up the wiring diagram to the antenna. I saw that the green/black wire to the antenna branched off to the HK amp before the antenna. So I moved the switch back to the antenna area. And all is well now.
Sometime when I'm bored I'll run a wire from the antenna switch into the cabin. I rarely listen to regular radio.
I have an FM modulator installed so with my iPhone I can listen to my music mixes and Pandora radio.
bliving7
Old Nov 18, 2012 | 10:41 PM
FireCrow's Avatar
Cheers for the info! I'm going to work on mine today, as I'm putting aftermarket stereo in, and the damn thing goes up when I switch stereo on. Don't want it, as I'm putting one with SD card reader... If I get stuck, I'll get in touch with you
Old Nov 19, 2012 | 05:37 AM
RJ237's Avatar
I have an aftermarket radio in my 95, and have the switch on my to do list.
goges
Oct 5, 2015 04:53 PM
Darrenmb
Sep 27, 2015 08:43 AM
Kaeghl
Sep 25, 2015 12:49 PM
kevinl
Sep 24, 2015 08:25 PM
