tech question: x300 very rough running...
Old Jul 18, 2010 | 05:07 AM
I am NO expert on the X300, YET, only what I have established since owning mine.
Keeeping it basic, codes not used for what I say.
Coils are an issue apparently, so a new set may be on the shopping lsit.
The "cam sensor" as such is I believe the pulse generator thingy in the hole where a distributor lived in a previous life. It may be faulty, or mis-timed.
The crank angle sensor, you found that I think, is a suspect after 100k miles, but it usually goes total, not erratic, so the engine just does NOT run.
Really BAD spark plugs, so bad the coils cannot fire them will give your issues.
Injectors not firing, which I THINK is to do with the cam sensor thingy, it sets the seqence of the injector firing order.
Throttle body may be FULL of gunge again after 1-2 years if the engine has been run conctantly with issues.
Getting back to basic steps one at a time are the only way of properly finding the bug/s.
Others will come in with testing procedures for things you requested I am sure, as well as ideas of cause of your issues.
King Charles
Oct 16, 2015 01:25 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
mat32essex
Oct 3, 2015 04:12 PM
280zx-turbo
Sep 28, 2015 04:37 AM
