Tell me about x300 brakes...
Old Feb 17, 2011 | 09:47 PM
zej's Avatar
zej
Default Tell me about x300 brakes...
Hi fellow Jag-ers,
Just wondering of anyone knows if the XJR brakes are the same as the 3.2, 4.0 and 6.0 litre n/a models?
Also, are they interchangeable with X308 or XK8/XKR items?
Reason I ask is that I took my XJR up for a 'spirited' midnight fang to the hills, and by the time I got to the bottom again, I'd well and truly cooked them! The discs were glowing dull-red and the pedal had gotten quite soft. I'm looking at some way of upgrading the rotors (on top of fluid + pads obviously...), such that I can still keep the original 17inch wheels, but x300 xjr aftermarket rotors seem to be a bit elusive.
Regards,
Jeremy
Old Feb 17, 2011 | 11:17 PM
Doug's Avatar
The XJR/6 brakes are the same as the N/A models and V12s. Not sure if the XJR/8 stuff will work...
Old Feb 17, 2011 | 11:34 PM
zej's Avatar
zej
Oh goody... that simplifies things, if an XJ6 rotor upgrade will also be an upgrade for an XJR.
Thanky muchly
Old Feb 18, 2011 | 10:47 AM
Japthug's Avatar
Hi. The brake calipers are all the same, but you can't use X308 rotors to X300s. It is because the front hub is different. If you want to replace your braking system with a bolt-on tuned one, you have to buy an expensive AP set or Arden set. Or you might be able to order some original braking systems to some tuning company. Then you would have to change your wheels too.
knightofgold
Feb 11, 2016 06:03 PM
mat32essex
Oct 3, 2015 04:12 PM
280zx-turbo
Sep 28, 2015 04:37 AM
42Ajd
Sep 26, 2015 07:04 PM
