Is there a way to get read the Check Engine error code without scanneron xj6 1997 ?
Old Dec 4, 2023 | 11:15 PM
vasey's Avatar
Default Is there a way to get read the Check Engine error code without scanneron xj6 1997 ?
Replaced altenator, everything works fine, but Check Engine light poped up. I am hoping it will clear, but to ease my mind I would like to know what is the error. Is there a way to get the code without the scanner tool?
Old Dec 5, 2023 | 08:36 AM
motorcarman's Avatar
A cheap 'scanner-tool' is something like $15 on ebay.
Why not buy one???
Old Dec 5, 2023 | 02:40 PM
944play's Avatar
If you have a smartphone or tablet, an ELM327 dongle can be had for even less than that. Bluetooth for Android, 802.11 for iOS, I b'lieve.
Old Dec 5, 2023 | 04:36 PM
Parker 7's Avatar
Alternator Charge light ?
Any auto parts store will read the code for free as long as you tell them you have a check engine light
Be sure to write the codes retrieved down
Your codes are on page 121 of the following doc
jagrepair.com/images/Training Guides/801S - 2000.pdf
Beyond the codes you can see live sensor data valus as you drive around with a ELM 327 , but there is a learning curve to setting it up
Video coming
Old Dec 5, 2023 | 09:44 PM
countyjag's Avatar
I think the answer to the actual question is no. Unlike some vehicles where you can prompt the car to give you a series of coded flashes, the X300 needs a scanner ( except for the HVAC which will flash numbers corresponding to faults)
Old Dec 5, 2023 | 09:58 PM
Parker 7's Avatar
See page 167 of the 801s Doc for XJ6 ( X40 ) with AJ6 engine OBD 1 , this is model up until 1994.5 so it does what you're asking but not yours
Page 52 for XJ6 ( X300 ) OBD 2 with AJ16 engine starting in 1994.5 to 97
rogerpaulsen
Apr 22, 2019 08:19 PM
jelu02
Jun 8, 2018 08:09 AM
Fermanaghman
Oct 30, 2012 08:34 AM
Boeingtravel95
Jul 22, 2012 09:37 PM
ron1979
Apr 8, 2008 12:44 PM
