thermostat stuck open???
Old Sep 21, 2008 | 07:21 PM
christian's Avatar
Default thermostat stuck open???
97 xj6 75,000 miles engine check light is on went to auto zone and it said coolant issue, i noticed that the temp gauge is just about always in the blue its like it never warms up...bad thermostat????
Old Sep 21, 2008 | 07:59 PM
Dennis's Avatar
ud
Default RE: thermostat stuck open???
Very possible or a bad temp sending unit.
Does it take a while to start throwing heat out the vents when heat is selected?..That will tell you if the t-stat is stuck open.
Old Sep 30, 2008 | 03:49 PM
Brutal's Avatar
its thermostat stuck open common on that model, be happy, you could have a v8 that tend to stick closed(alot) and make you overheat on the side of the road. Its easy to change right on the top of engine, takes about 5 min
Old Oct 2, 2008 | 03:03 PM
whiteSTR's Avatar
Definitely sounds like your thermostat.. try replacing it, but I would only use OEM parts with something like that..
Doug
Feb 27, 2019 01:31 AM
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
jehart49
Sep 12, 2015 05:36 PM
findre
Sep 10, 2015 05:46 PM
