Throttle body gasket
Old Jun 23, 2022 | 07:41 AM
cdma's Avatar
Default Throttle body gasket
I have taken off two throttle bodies over the last year and one had no gasket or gasket material and one had gasket material. What is recommended and if it needs gasket material what should I use
Old Jun 23, 2022 | 11:26 AM
Nobeel Masri's Avatar
There should be no gasket between the throttle body and intake manifold.
Just make sure the surfaces are clean and the bolts are tightened properly.
Old Jun 29, 2022 | 02:22 AM
countyjag's Avatar
Agree, no gasket or gasket material
Old Mar 1, 2024 | 11:00 AM
Jo van Haag's Avatar
Default Throttle Body Gasket
Hallo tergitkerd,
soweit ich weiss ist die erste Dichtung für den 2,5 l und die zweite Dichtung fits denn 3,0 l
Hello tergitkerd,
as far as I know, the first gasket is for the 2.5 litre and the second gasket fits the 3.0 litre.
https://www.drivparts.com/part-detai...nting%20Gasket
Old Mar 1, 2024 | 12:55 PM
Vee's Avatar
Vee
There is no gasket for the AJ16 engine.
If you feel the need, then I would suggests some non-curing fuel resistant material such as Permatex Permashield 85420 which is similar to Hylomar.
XJ6Paul
Jun 4, 2019 01:23 PM
Vee
Mar 20, 2017 12:56 PM
Dan Hiatt
Aug 1, 2014 08:19 AM
The Coupe
Dec 28, 2012 02:31 PM
