Throttle body "Re and Re"
Old Dec 30, 2022 | 11:58 PM
Anbran's Avatar
Default Throttle body "Re and Re"
In working on my throttle body, I'm at the stage of reinstalling on to the engine and I started to strip the four bolts very slightly.I guess I'll have to "clean" them up a bit...
Any recommendations? Are the bolts metric? What size are the threads? Tap and die or thread restorer?
Thanks,,,
Old Dec 31, 2022 | 12:20 AM
Spud Maat's Avatar
tap and die kits are fantastic.
if you jump on google you will easy be able to find out how to measure your thread.
something bout the length of the bolt/stud and the number of threads will give you the thread size,
and the bolt size is measurable via diameter of the bolt..
not sure at all what size these bolts and threads are and would hate to give you the wrong info
Old Dec 31, 2022 | 12:49 AM
Parker 7's Avatar
Most hardware stores with a good individual bolt selection in the bins have a mandrel to thread into to find the bolt thread size
They should be metric
You can take a selection of nuts to thread on to also determine the size of the threads
You will have to do several nuts to ensure what you have in hand is the size on the label as they can be mixed
If the original holes " may " have a helicoil insert you can replace the insert
Otherwise you can install a new helicoil installation with a kit
There is a torque setting on page 10 of the doc below
Throttle body to intake manifold 21.5 to 28.5 Nm
190 - 252 inch pounds
guy
Jun 12, 2021 01:40 AM
Crandell
Mar 21, 2019 11:44 PM
fredd60
Mar 10, 2019 09:01 PM
Matt
Jan 12, 2011 01:30 PM
jagman96
Nov 1, 2010 11:40 PM
