Torque Rating?
Old Mar 22, 2018 | 06:35 AM
95Leaper's Avatar
Default Torque Rating?
Does anyone know the torque specifications for the large center rear hub bolt? Also for the lower shaft pivot bolt on the rear hub carrier. Thanks in advance!
Old Mar 22, 2018 | 10:55 AM
Jagboi64's Avatar
You mean the axle shaft hub nut for the first one? That is 304-336 N-m. The manual has the following notes:
The axle shaft nut is a self-locking item with a thread insert and must NOT be re-used. Assembly and fitting is the reversal of this procedure taking note of the following:
-Prior to assembly, remove all traces of old adhesive from hub splines.
-Loctite 270 Adhesive should be applied to axle shaft splines over a radial area of 30 to 50%.
-Renew all bolts that were originally fitted with thread locking adhesive.
-Check and adjust rear wheel camber setting.
-Verify operation of brakes.
The lower shaft is 80-100 N-m
ilovetrains
Mar 25, 2010 09:41 AM
JoyceandJay
May 28, 2009 07:44 AM
jjones91
Oct 24, 2008 04:54 PM
Michigan
Jan 8, 2008 09:52 PM
