Transmission oil pan with drain plug.
Old 08-22-2017, 11:57 AM
rendo's Avatar
Default Transmission oil pan with drain plug.
Anyone familiar with a commercially available source for a transmission oil pan fitted with a drain plug?
Old 08-23-2017, 01:13 AM
Lady Penelope's Avatar
Received 1,383 Likes on 1,087 Posts
https://www.jaguarclassicparts.com/u...-3-2-4-0-litre
Well at least the part numbers are reasonable . Might have to repair the pan somehow . Trouble getting the plug out ? Took me several days of soaking with penetrating oil and a long leverage bar . You should have seen the oil .
Attached Thumbnails Transmission oil pan with drain plug.-x300-oil-pan-untitled.png
Old 08-23-2017, 07:08 AM
aholbro1's Avatar
Received 1,642 Likes on 1,068 Posts
OP probably has a pan with no drain fitted...some didn't. I don't recall ever seeing a date nor VIN associated with the changeover. I have a 95 with no glove box, and 2 '96's; all have xmsn drain plugs.
Old 08-23-2017, 09:28 AM
Depending on you situation if you have stuck or damaged hex nut you might consider sucking the old oil out through the servicing pipe with a egg pump or evacuation pump . You can take a 1 gallon wine bottle and hook it up to vacuum cleaner . A rubber cork can be obtained from homebrew supply store as well as tubing and a 1 gallon bottle at a glass recycle bin . You have to warm up the oil alittle bit to flow easier . You may not get all the old out but better then none .
Old 08-23-2017, 09:34 AM
Received 7,896 Likes on 4,770 Posts
The dipstick tube fitting can be removed and the oil drained.
bob
