Transmission / starting
Old Oct 9, 2020 | 06:06 AM
haroldpeacocksr's Avatar
Exclamation Transmission / starting
1996 XJR. Car wouldn't start; (no power of any kind) If I put it into park "hard" then sometimes it worked. I was advised to replace the Transmission Decoder. a small 3" plastic unit with a slider in it mounted under the shift lever panel on the side. This resolved the problem, temporally, now I have a new problem, the mechanic that did the work didn't do the job correctly, now the shifting mechanism is all out of whack. I called the Jag dealer in Seattle and they don't work on this older car (96) and neither do the two garages they recommended. . .So! Does anyone know a mechanic/garage within a 100 /200miles of Tacoma that I could take my XJR too?. . ."HELP"!
haroldpeacocksr
Oct 9, 2020 02:54 PM
haroldpeacocksr
Oct 8, 2020 02:43 PM
Shane8362
Sep 6, 2012 06:56 PM
Shane8362
Aug 27, 2012 06:49 AM
