Trapped in Jag!
Old Feb 9, 2010 | 10:52 PM
holybananas's Avatar
Exclamation Trapped in Jag!
Out of nowhere today the interior driver door handle wouldn't open the door! The exterior handle still functions as it should. I took off the wood panel and discovered the cable from the handle to the door release has come apart.
Does anybody know any fixes? or off hand anywhere I can purchase one of these cables?
I've checked eBay and they are all for the wrong doors.
I've attached some pictures of my broken cable.
Thanks!
PS: I guess I should have cleaned the areas in the pictures lol
Old Feb 10, 2010 | 12:19 AM
panchostatus's Avatar
naw you good.
as long as I'm trapped in there with my girl I'm good
but! if not, you will need,
either,
a crimp tool, & a rather strong cable crimp type substance,
or
a welder
or
a new cable.
hit up motorcars LTD or call up coventry west, or if you're like me and got lucky and claimed a jag at the local boneyard, (homeboy at the yard calls it 'pancho's jag' sitting out there) hit that up & ****** the cable.
binder clips = fail
creativity is essential in this fix if you dont end up sourcing a new cable.
nut&bolt humdinger could even be a possible fix if you're good.
I've had a few of those on a 98 318ti I used to have, but nothing so far on my jag children
Old Feb 10, 2010 | 12:22 AM
I ended up removing my door during a speaker install & welded the hell out of mine
Old Feb 10, 2010 | 06:21 AM
Fraser Mitchell's Avatar
Should be the same as the XJ8 (X308 model), and probably the late year XJ40s. I would not think this part is expensive, it is the finding of it that is the problem.
Old Feb 10, 2010 | 07:44 AM
Doug's Avatar
I've heard of some owners going to a bicycle shop and finding a cable that works <shrug>
Old Feb 10, 2010 | 06:21 PM
cutlass's Avatar
british car recycling in rancho cordova CA sells them for $20
VinnyT
72
Sep 28, 2025 12:17 PM
Doovoe
Sep 8, 2015 05:42 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
MrMellor
Sep 7, 2015 10:22 AM
Rick Michael
Sep 6, 2015 06:53 PM
