Trip computer stuck on miles
Old Nov 11, 2021 | 03:31 PM
Spud Maat's Avatar
Default Trip computer stuck on miles
As title says my trip computer is stuck on the miles setting.
and being in AUS i want it on KM but the switch does not change it.
is this something others have seen before?
i noticed cus my fuel use readout goes up on freeway driving and down in heavy traffic indicating it is set on MPG.
I can flick the switch from miles to km and nothing changes at all.
best i can do for now is know that 16.8 is the point where MPG and L/100KM is the same
Old Nov 11, 2021 | 03:41 PM
Parker 7's Avatar
You probably do not need to replace the switch but just jumper it once to switch it over and then remove the jumper
It's probably a momentary contact switch like the reset and clear button on the same package
Old Nov 11, 2021 | 03:44 PM
Spud Maat's Avatar
What needs to be done to access the switch?
is it just one bit of the plastic trim that needs to come off?
Old Nov 11, 2021 | 03:59 PM
Parker 7's Avatar
if you can pull the connector off just ground the Red color wire to ground
the ignition switch probably needs to be in the run position
See edit above
Old Nov 11, 2021 | 04:06 PM
Spud Maat's Avatar
Thanks,
will add this to my ever growing to do list
Old Nov 14, 2021 | 05:27 AM
Spud Maat's Avatar
ok, so fixed.
nice and easy.
took out the pcb, saw the solder joints on the back for the switch were gunked up, got out the isopropyl and a tooth brush... gave her a nice clean...
bada bing bada boom. working. now if only all problems were this easy.
rsmartin
39
Nov 12, 2021 01:09 AM
gibbon
Nov 22, 2017 07:34 PM
mbelanger
Feb 21, 2014 08:15 PM
carelm
Apr 15, 2012 10:48 AM
