trunk latch mechanism
Ok so my trunk wiring harness is busted and I had to break in with the screwdriver trick. While I was in there I decided to remove the latch (GNA3500AB) and found the manual lock rod dangling, which explains why it never worked.. Later I accidentally let the electric actuator rod slip off and forgot its position.
Which rod goes on top, which one goes on the bottom? Thanks
