Turn siganl and headlight bulbs
Old Sep 10, 2008 | 12:22 PM
RickSku's Avatar
Default Turn siganl and headlight bulbs
This 95 Jag XJ6 has a cracked headlight and still works. I am afraid with wet weather comming it is going to burn out. From what I see you take the headlight chrome ring off and change the bulb is it that easy if not tell me how. Now my other problem is I have the drivers side turn signal bulb burned out and I don't see how that is changed. I read somewhere that I have to remove the front bumper. Any advice is appreciated. This is my first jag and I want to keep it but I want everything working.I hope I posted this in the right place.Thanks RickSku
Old Sep 10, 2008 | 04:39 PM
ken@britishparts.com's Avatar
Default RE: Turn siganl and headlight bulbs
The headlamp bulb is change from the rear. You will see a locking ring where the wires go in. Be fore warned, you probably won't pass your state inspection with the cracked lens.
The turnsignal is a pain in the @$$. It's much easier with a lift. You have to come from the backside. Removing the bumper is not necessary, but it may help if you snap your arm between the wrist and elbow.
Old Sep 17, 2008 | 06:47 AM
RickSku's Avatar
How hard is it to take the bumper off?
Old Sep 20, 2008 | 06:12 PM
jag_genius's Avatar
headlamp just pulls straight off.. turn signal.. just pry out with a plastic bone tool .. or if you wanna remove the bumper 2 19mm bolts under bumper.. then one harness connector passenger side.. then pulls straight out..
99xk8guy
May 28, 2024 09:36 PM
afterburner1
Dec 16, 2015 12:12 AM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
King Charles
Sep 3, 2015 12:40 AM
