Tyre size - 215/65?
Old May 18, 2019 | 03:01 PM
Carl Johan Paulsen's Avatar
Default Tyre size - 215/65?
Hello,
I just bought a great X300 from 1994. 4,0 Sovereign. However, the tyres need replacement.
Currently, it has 225/60-16s. But I was wondering, if 215/65-16 could do instead? Or 215/60-16..? They are substantially cheaper..
Thansk in advance.
Best regards
CJ
Old May 19, 2019 | 02:20 AM
SleekJag12's Avatar
A few things to consider in your decision (but things you might already know):
The original size is 225/60-16. A variation in width or aspect changes the sidewall height. In this case, a 215/65 will be slightly taller, while a 215/60 will be slightly shorter than the 225/60. A change will slightly affect the speedometer and odometer accuracy. Also, the final drive ratio will be a little different.
More importantly, the original spec for load rating is 97. The 215/60 is usually carries a 94 or 95 load rating. If you look around you can probably find a few in this size with the XL rating which is usually 99. Falken Ziex is one example. Choices are limited. I see that most 215/65 tires are load rated at 98 or above, so no worries there, and many choices.
The original Z speed rating is equivalent to a V rating I believe (V+?). I think it is a good idea to keep to at least an H rating, if not V. But don't take H rated tires out on the Autobahn!
A tire shop might refuse to sell you tires that have a lower load rating (or too low a speed rating) than the originals.
Some non-USA cars have sport suspension which would include wider 8" sport rims. I don't think the narrow 215s would fit or look right on the sport rims.
Old May 19, 2019 | 04:13 AM
Thank you for the good answer. I know about the pro's and con's in terms of speedometer readings etc. But was also curious if any of you had tried other sizes?
CJ
Old May 22, 2019 | 10:20 AM
littlelic69's Avatar
Be Careful! My insurance company gave me permission to use lower speed rated tyres than originally specified - and warned that without this authorisation, my insurance cover COULD have been made void!
Old May 22, 2019 | 01:22 PM
AL NZ's Avatar
Originally Posted by Carl Johan Paulsen
Hello,
Thansk in advance.
Best regards
CJ
Carl , for what it is worth, my Daimler 6 (1995 3.2) wafts along beautifully on Michelin Primacy 3ST 225/60 R16s . quiet, good handling, good wear. 120km/h feels like 90.
HNB
Nov 2, 2013 04:44 AM
dietrich
Nov 8, 2012 08:35 AM
aceofspade215
Oct 18, 2011 11:46 AM
ant17
Apr 5, 2011 05:20 AM
exexpat
Jan 10, 2011 01:27 PM
