Use a Larger than OEM Auxiliary Water Pump?
Old Nov 16, 2021 | 01:10 AM
Ken X300's Avatar
Default Use a Larger than OEM Auxiliary Water Pump?
Hi Folks,
I need to replace the auxiliary (secondary) water pump on my 1997 XJ6 w/ 4.0 (NA). The original is a Denso MNA6710AB and I just happen to have a new Bosch
0 392 022 002 0 392 022 002
that is used on the X308 AJV8. I'd need to splice a Bosch connector onto the pigtail from the Denso and jerry-rig bracket mount but that shouldn't be a problem.
The question is will installing an auxiliary water pump that is larger than OEM cause any immediate or long term damage or should I not worry?
I tried to find flow rate and pressure specs for the Denso to compare to the Bosch but came up empty. Thank you for any help.
Denso MNA6710AB Auxiliary Water Pump
Bosch 0392022002 Auxiliary Water Pump
Old Nov 16, 2021 | 01:18 AM
Parker 7's Avatar
The solenoid to regulate the needed flow of coolant is by the climate ECU so any overage is automatically throttled back to maintain the set cabin temp as it normally would
Old Nov 16, 2021 | 08:02 AM
xalty's Avatar
lol a cobra pump, that’s for IC circuits. sell it for some money and go buy one of these
https://www.ebay.com/itm/Auxiliary-C...-127632-2357-0
Old Nov 16, 2021 | 12:31 PM
Ken X300's Avatar
Thanks for making me some money xalty. I've ordered the one you recommend and I'll throw the old one up on ebay later.
Thermo
Feb 5, 2025 07:50 AM
Michael?
Jul 23, 2021 11:07 AM
roger.neill
Dec 22, 2013 08:39 AM
perezrp101
Apr 15, 2009 09:02 PM
