Vents blowing heat & cold
Old May 25, 2014 | 10:08 PM
rjaguar's Avatar
Default Vents blowing heat & cold
Hi folks!, I did a pretty extensive search, and I'm not seeing exactly my situation, but several close ones.
I've noticed that the AC / Heating system on my 1997 XJR X300 has an issue by blowing Heat in passenger side vent and Cold in driver and even the (middle) center vents blow half heat and half cold, by changing the temperature I can see the difference in the driver side but nothing on the passenger! and my car has Solo climate control,
Thinking about heater core being plugged or probably blend-door issue.
So please tell me where to start the diagnosis.
Rabeea
Old May 25, 2014 | 11:18 PM
Suede's Avatar
The heater solenoid valve could be stuck open. It's the valve hooked up to the auxilary water pump next to the brake booster. If it is stuck open, then hot fluid will flow continuously through the heater core.
Old Jun 1, 2014 | 12:40 PM
steven300's Avatar
its possible that a blend door is stuck,those doors are in the dash and are controled electricly...steve.
02jagstype
23
Oct 23, 2022 07:03 PM
Poet
Oct 6, 2015 09:40 PM
twinstacks
Sep 19, 2015 01:09 PM
stype40
Sep 9, 2015 08:14 AM
Corycarlo
Sep 5, 2015 11:41 AM
