Which ECU emissions region codes correlate to a country/region?
Old 06-04-2018, 09:36 PM
al_roethlisberger's Avatar
Question Which ECU emissions region codes correlate to a country/region?
I may be on the search for a replacement ECU, and will of course need to match the part number. I haven't pulled mine out yet, and when I do I'll undoubtedly have the exact part number.
But until then, I was looking at Jaguar Classic parts and found the ECU part numbers for my XJR6 VIN range to be broken out into three emissions groups, A, C and E.
In my car's case, the C&E group are the same part number, but the A is different.
So I was curious if anyone knew what countries/regions these emissions groups mapped to?
Old 06-09-2018, 03:00 AM
SleekJag12's Avatar
Hi Al, check the last prefix letter before the six-digit serial number on your car's "born-with" VIN next to the battery. For the XJR, T=emission A, P=emission C, and J=emission E. I don't know which regions are which, but we will find out which one is USA soon! Hopefully this helps somehow and the information from your ECU will match up.
My 6.0 is emission D. ??
al_roethlisberger (06-11-2018)
Old 06-09-2018, 04:06 AM
GGG is online now
Received 16,800 Likes on 12,169 Posts
The Jaguar VIN decode for X300 (1995-97) may help or could further confuse:
Strangely, JEPC lists ECM's for Emissions A, C and E with further subdivisions under each for VIN range but does NOT include or categorise by Country/Region.
Attached Thumbnails Which ECU emissions region codes correlate to a country/region?-emissions.jpg
The following 2 users liked this post by GGG:
al_roethlisberger (06-11-2018), Lady Penelope (06-09-2018)
Old 06-11-2018, 03:19 AM
SleekJag12's Avatar
The above chart has additional information compared to my original 1995 in the book. My version is an early one. However, I double-checked my VIN and discovered I was wrong about the emissions code. It is T, not C, therefore I have emission A! Notice that neither "T" nor "emission A" is listed above for prefix 11!
T =A is listed for the 4.0S/C as well in my book. If everyone checks their 11th letter, we would get a good picture of the emissions regions! Maybe.
Funny that California had to have a 4.0 engine code all their own...
Old 06-11-2018, 08:26 AM
I'll try to get out today and look at the "born with" VIN and also post both my USA VIN.
You say the "born with" VIN it is near the battery, but where normally?
Old 06-12-2018, 01:52 AM
SleekJag12's Avatar
It is on the edge of the spare tire well next to the battery. Large stamped digits, can't miss it. It follows the chart that Graham posted above. The 6 digit serial number will be the same on both VINs. As far as I know that trunk location is the only one on USA models. It is the original proper English VIN and heritage that the car was born with!
Johnken
01-04-2017 09:56 AM
orangeblossom
03-03-2016 03:15 PM
BadCat
02-21-2011 03:23 AM
AGLXTYPE
01-11-2008 11:15 AM
Quick Reply: Which ECU emissions region codes correlate to a country/region?
