Water pipe leak
Old Feb 19, 2018 | 10:36 PM
Droneman's Avatar
Default Water pipe leak
water pipe gaskets let go underneath the intake manifold, 1995 xj6. The only way to access the two sets of two bolts is to undo all of the intake manifold nuts/bolts, but complete removal is not required. No need to worry about the harness going thru the intake. Best way is to put a 2-3 foot wide board across the passenger front fender and top of engine, get a step ladder and climb on up, undoing all off the intake fasteners, not too bad of a job. Need to dis attach some electrical fittings and tag. Push intake out of the way, reach down and unbolt the four fasteners, remove and clean the water pipe and reassemble with new gaskets. Also a good time to do the ******* hose.
Old Feb 19, 2018 | 10:38 PM
Droneman's Avatar
I can't believe they blocked the 'bast$&@', it's not a profanity.
Old Feb 20, 2018 | 06:45 AM
katar83's Avatar
I'm pretty sure you can get to water rail bolts from underneath the car, the oil filler housing is in the way but that's easier to remove then the whole intake and you might be able to do it without removing it anyway, depends on your hand size and how quickly you get annoyed
I did this on an XJ40 which is pretty much the same engine, although I've snapped one of the bolts while undoing it so had to remove the intake anyway. They are quite fragile.
Old Feb 20, 2018 | 07:04 AM
aholbro1's Avatar
Originally Posted by katar83
I'm pretty sure you can get to water rail bolts from underneath the car....
I did this on an XJ40 which is pretty much the same engine...
Give it a try on an X300 and get back to us.....
Old Feb 20, 2018 | 07:20 AM
katar83's Avatar
No need to, I can always check a pic in your own thread that shows the water rail and can see straight away that I'd be able to access these bolts from underneath the car
Old Feb 20, 2018 | 07:59 AM
Droneman's Avatar
I tried from underneath, could''t reach the bolts, but didn't remove the oil filter housing, as suggested. Took a look at the starter while I was under and am hoping I never have to wrestle with that.
ln69bt
46
May 26, 2018 01:39 PM
Northern XF
Jul 30, 2017 09:03 AM
Evan Trinh
Feb 25, 2016 06:04 AM
vincent661983
Jan 31, 2013 08:01 AM
plums
Jan 3, 2012 02:57 PM
