Weird buzzing noise from driver side ac vent
Old Oct 28, 2020 | 01:28 PM
JezuzNoChill's Avatar
Default Weird buzzing noise from driver side ac vent
Noise doesn't change with fan speed and it's only when the fan is on.
https://photos.app.goo.gl/AmYyCkPWGUXdFWam8
Old Oct 29, 2020 | 05:07 AM
countyjag's Avatar
I am going to go for a bit of leaf or debris ingested into the fan and touching the blades as they rotate.
I had been wondering about the climate control system aspirator, which is a tiny fan which draws air over a thermocouple to determine the cabin temperature, but it looks as if your car is LHD, and I think it is always located in the RHS knee area. It has a plastic cover about an inch square, and is worth checking anyway, as the thermocouple will likely be covered in dust and would benefit from a clean
Old Oct 30, 2020 | 01:03 AM
SleekJag12's Avatar
The aspirator is on the left on LHD cars. It does get dirty and can be audible. Only used when the climate control is on. Take off lower left panel below the dash vent to clean. It has a disconnectable wire lead.
Old Nov 3, 2020 | 04:13 PM
It was the temperature sensor fan. Tried cleaning it and put a drop of motor oil on it but it's the same noise.
TheFrenchJag
May 28, 2020 12:51 PM
SS4PK
Jun 19, 2019 08:29 PM
Kikzin
Jul 15, 2018 09:09 AM
James Lewis
27
Aug 22, 2013 06:06 PM
avt007
Aug 6, 2013 10:54 PM
