What is this?
Old Feb 6, 2014 | 01:51 PM
sogood's Avatar
Default What is this?
Just doing some odds and ends today, when I noticed something on the air filter housing box. Underneath the box itself, is a plastic pipe, about 1" diameter and about 2" long, There is a yellow plastic blank fitted over the end of it, with nothing else attached. The pipe faces back towards the windscreen. Just wondered what it is, what it's for?
Thanks.
Old Feb 6, 2014 | 03:57 PM
caldercay's Avatar
Talking about this hose connection (right-side arrow)?
That leads to the air injection pump (left-side arrow)
Old Feb 6, 2014 | 05:30 PM
sogood's Avatar
It's hard to say from that picture, but thanks for the reply. The pipe I'm talking about is very clearly visible from the drivers side wing/fender, (RHD) looking straight across the engine bay. Maybe a picture would have helped! I'll take one tomorrow and post it if needed.
As mentioned, there is nothing connected to this pipe, just a blank cap.
Thanks again.
Old Feb 8, 2014 | 07:23 PM
zathras's Avatar
Thanks again.
When I removed my air box to fit the K&N I also noticed the yellow blanking cap under the air box. Here is a photo of the box from underneath
Old Feb 9, 2014 | 03:40 AM
sogood's Avatar
That's the one, thanks. Maybe it's a "drain" or outlet of sorts? I'm not worried but quite curious! But then again, perhaps it IS for an air injection pump, which I don't seem to have.
Old Feb 9, 2014 | 05:18 AM
sparkenzap's Avatar
If water was to collect in the box, it will drain out the bottom through that port. Other cars just have a drain hole.
Old Feb 11, 2014 | 04:47 AM
SleekJag12's Avatar
As Caldercay pointed out, that fitting would connect to the air pump as fitted to USA models, as required by US emissions laws. Air pumps are not fitted to UK, NZ or AU models. I wonder if it was fitted to any other markets?
Old Feb 11, 2014 | 04:51 PM
sogood's Avatar
So, given my limited knowledge of the science involved in air intake physics, would it be of any value to put another air intake onto this "spare" pipe? Maybe a tube /hose arrangement with an aftermarket K&N air filter set up attached.
How would extra air affect performance and fuel consumption, if at all? Or would it be of any value to vent warm, recycled air into the system via this pipe? Or what about pumping it in, via a controlled electric pump, which is what I assume the American spec cars do?
Just wondering................
Old Feb 12, 2014 | 01:33 AM
zathras's Avatar
Well that air box I photographed is from an ex-Sinapore car so I guess that means in that market they are the same as UK then
