What did you do to your X300 today?
#661
Any luck with the CD player code as I can remove the patch cable from the donor car and you can hook up with the CD changer sitting it the passenger seat for testing
When you get the CD player straightened out here is a very British song for you to enjoy . So much so it makes the queen cry
From 1898 so it's high faluten music so shut the engine off and close your eyes and think of England and it's majesty as you absorb it's richness.
https://www.youtube.com/watch?v=lUpvEgJEn94
I have completely given up on CD players.
I have the cartridges if someone would like them. Just let me know.
I am still astonished at how smooth the idle has gotten and the on off throttle transitions since changing the fuel filter. If you have a slight idle stumble and a odd transition off throttle (Like a hard fuel cut form the ECM) replace your filter now!!
Lady Penelope (11-08-2018)
#662
Welcome aboard, Emily! Glad you've joined us. You'll find folks with more in common and probably topics of greater interest to you in this section of the forums, as you have the F-Type:
https://www.jaguarforums.com/forum/f-type-x152-72/
Meanwhile, you should repost your intro here, https://www.jaguarforums.com/forum/n...-intro-must-5/ in the new members area, so people can give you a proper welcome and a moderator can take notice and track your progress to full-status.
#665
#666
On the cup holder mount:
I have tried that as well.. It always breaks again.
I made a slight modification to your description.
I put in a little metal strap around the outside of the hole and used a tiny wood screw to fasten it to the plastic. It's been solid now for nearly 50k Miles. (the strap is about 2 inches long by 1/8th inch wide wrapping around the entire area and epoxied with the rest)
#667
Got my 97 XJ6L from the shop, 190K miles
New ball joints, New wheel bearings and seals all around. New shims on rear end for alignment (getting hard to find, the aftermarket fall out) Transmission service, Fixed exhaust manifold leak. 97 XJ6L
Now on to the 96 VPD. 201K miles: Heater core leaking, Air-bag light on, Air-Conditioner compressor failing.
#668
There is a PDF on my laptop of someone making a excellent testing of the X300 airbag system . If I can find it after a while . One of the salvage yards in the LA area that has alot of Ebay listing seems to have them and ships by mail but your not suppose to ship .
Airbag PDF file below :
Century Air has the reseal o- ring kits for the Denso 10PA - 17 ( off the top of my head )
https://www.shopcenturyautoair.com/s...-10PA-SYS.html
See video part 1 and 2 :
They carry the clutch coils and a video on how to replace
The 10 mm nut on the shaft can be taken up to a shop and have them remove it with you supplying the 10 mm impact socket that they may not have
MikeyB10 (11-13-2018)
#670
Replaced these:
With these:
The old ones are now in a Deox-C bath
New ones were too, they came of my old x300, if anyone needs to refurbish these I can highly recommend Deox-C, not a spec of rust on them when they came out of it.
I did replace all seals and pistons too. Fun fact, everyone tried to scare me how complicated refurbishing calipers is when reality is, it was one of the easiest jobs on a Jag.
With these:
Lady Penelope (11-13-2018)
#671
I've been living with a noisy compressor for 3, maybe 4 years now, since its been working fine and I thought repair would either mean a replacement or at least compressor removal and then regas which would be a major PITA, I thought I'd just leave it until it fails completely. As it turned out the clutch bearing can be replaced with the compressor still connected to the system and I've only just found out a week ago, thanks to a great post by Lady P.
I've purchased a replacement bearing(30x52x22mm), which cost £12.56 and proceeded with repair which turned out to be very simple, rather very rare thing for a Jag.
Had my brother hold the clutch and I've undid a bolt in the middle holding it, all done from underneath the car, then I tried for 25 minutes to get to the circlip holding the clutch only to give up. I've undone 4 bolts holding the compressor, moved it back by maybe 15cm and could finally see this devilish contraption and could get my circlip pliers onto it!
Circlip then removed easily and the whole clutch came off. I did make sure not to loose two tiny special washers while taking it off.
Bearing was hammered out and new one hammered back in(using the old one).
Fitted it all back
and the noise is finally gone!
Surprisingly the old bearing seemed fine, no damaged to rollers or seal, only movement was back and forth but only by maybe half a mm but that was enough to create all that annoying noise
Very happy with results!
Fitted it all back
The following 2 users liked this post by katar83:
Lady Penelope (11-18-2018),
MikeyB10 (11-21-2018)
#672
Ric in RVA (11-19-2018)
#673
#675
Nice work, Can you describe the "annoying" noise? Mine makes an imminent squeal whenever I have it running. Originally thought it may be a loose belt but doesn't have the increasing pitch of that annoying problem, Just generally a constant squeal at idle. Hoping this may be my fix.
MikeyB10 (11-20-2018)
#676
Mind you, without a belt when moving clutch by hand it didn't make any noise at all and felt fine, apart from the back and forth movement by maybe half a mm. Like I said that was enough for it to squeal.
#677
Hi,
I have done two mods to my XJR6 over the last few days.
X308 headlamp modification - I do prefer the look of the X308 headlamps (not that I want my car to be a "fake" 308). I got my 308 headlamps for £45 shipped from eBay, which I thought was pretty good and all bulbs works!
I also have been over-thinking the practicalities of audio, DAB radio and Bluetooth in a 20 year-old car. I did consider replacing the stereo, but did not want to damage the OEM look or do anything that could not be hidden or reversed. In the end I went for a Pure Highway 600, this usually connects to the OEM stereo by AUX-in, which our cars do not have, or it can broadcast via its own FM transmitter, which is working pretty well. It offers DAB radio and hands free Bluetooth calling / audio streaming and has a button to active your phone's hands free commands by "Hey Siri" or similar.
I had this mounted on the leather surround of the AC/stereo controls. I got this pretty cheap on eBay for just under £90 (Halfords want £150). The gadget in the picture is basically a remote (and is AAA battery powered, which they claim lasts for a year) the real intelligence is in the antenna which is mounted on the window, which I had hardwired to the power of the car as I did not want cables trailing to the cigarette lighter.
Hope this is of some interest.
Cheers,
nickdabs
Cheers,
nickdabs
#678
Looking good. I've been wondering about different audio options myself. I'll keep an eye out for you around town :-)
Hi,
Cheers,
nickdabs
Cheers,
nickdabs
#679
Fell back in love with it. Ever since I bought my new motorcycle about a year ago I kind of shifted my attention to it. Now that the thrill is gone I have a renewed love for the x300.
Now I have to figure out the driver seat inop issue. None of the functions work. Will check fuses this weekend. If fuses are good I guess I'll check out that control module I've been reading about.
Also have to try to get interstate to warranty this year and some months old battery that's testing bad.
#680
smartobject (12-04-2018)
