Re-glued the high mount (3rd light) brake light to the rear window and got my console all back together after repairing the radio and clock, and adding USB power under the dash and inside the console along with a lighter socket in the rear.
Al, my rear high brake light has also fallen off
what glue did you use? cheers, Al |
Originally Posted by AL NZ
(Post 1388208)
I replaced my Crank Position Sensor @ 119,*** miles and wow. The vehicle idles so much better. So much quieter and smoother.
Originally Posted by SD96XJ6L
(Post 1388816)
I swapped out my steering rack from my donor car about a fortnight ago. Mine was leaking. Smoother, quieter steering now. Two days back I did an oil change, new filter, air filter, cleaned up the plugs, which were happily a nice clean tan colour as they should be.
Flushed and replaced diff oil. Topped up transmission fluid and sorted out an intermittent rear light. It used to go on and off with every bump in the road. Just a bad contact at the connector. While down under the car, I noticed some rust which will need attention. It's on the rails up at the front end. Will post some pics soon. Likewise some rust behind the front wheels, at the bottom end of the wheel wells where they meet the sills. Not a big fix but I want to stop it going further. Still a few other jobs on the "to do" list, but aren't there always! |
Yesterday, I spent about 5 hours working on my Jag while my brother got his Eagle SX4 ready for the road!
Inspected the undercarriage, and I have to say, it's completely rust free! A Canadian car, exposed to ice and salt! What? So the -only- rust on the car is the rear wheel arches, and of course a bit of surface rust on the exhaust. Definitely surprised me. I noticed that my lower ball joints up front are open, though I'm not getting any noise or anything. I'll be packing them with grease and replacing them soon. Couldn't find any play in the transmission, as I'd expected the mount to be on its way out--could a bad spring cause weirdness under load? I also found the balls to play with the alignment, since the toe was out by a few inches. My first attempt was dangerous. Second attempt was better, and my final attempt was perfect except the steering wheel is off centre just a bit. I'll be fixing that today. I also cleaned up all the ground points, but I couldn't find a supposed trouble zone which is supposedly behind the firewall near the arch? I also found only one engine ground, and I was sure there were more than one. Maybe I was just tired. It was a good day for some learning, and my plans for spring are to replace every bushing as well as the rear shocks--then I'll sort out some of the gremlins. A panoramic sunroof is officially on my to-do list, and I'll be extending the headliner biscuit for more head room, and also because the new sunroof won't need to tuck itself under the headliner. |
(Post 1388208)
what glue did you use? cheers, Al . |
Got some good and bad"ish" news from the mechanic the other day when they performed an oil change and overall inspection.... they finally observed and confirmed that something isn't right with my brakes! Finally.
I've been saying from the day I bought this car, and after pad changes, etc.. that the brakes on this car just seemed like there was way too much effort necessary to get them to initially bite. But not having ever driven another X300 and having the mechanics test drive it before without being able to confirm the issue, they finally noted that something is amiss the other day. So that's a relief to finally have someone confirm something isn't normal as I just couldn't believe the brakes were this poor on this car, and couldn't attribute it to their just being "softer" than other cars on the X300 as we've discussed here often. Mine are just too hard to get to initially bite, like I don't have power brakes. Now, so far we don't know why, but I suspect the booster. I have to take it back for a thorough inspection of the brake system to identify the issue. . |
(Post 1388208)
what glue did you use? cheers, Al Thermostat was stuck open on the Black 96; Inasmuch as we only recently obtained it, I thought if replacing T-stat, I should renew the coolant, if renewing coolant, I should renew all the hoses that carry it. Removed the T-stat, flushed the cooling system with distilled water, back-washed the heater matrix, renewed all the hoses save one - Rad-to-header tank new hose was a 3-ended affair, ostensibly requires a single-nipple header tank - this one has 2 nipples, one to rad, the other to T-stat housing. Re-ordered the proper right angle hose for future fitment - but this can be changed without coolant loss. Topped up with a little over 6L of Zerex G-05 for a 50/50 mix and as Grant may say, "Sweet as...." Hoses were surprisingly pliant and appeared in good-nick. Particularly surprised by the B*st*rd hose - pliable and "fairly" easy to remove as opposed to the one on my 95 which was more the consistency of fiberglass than rubber when I changed it last year. I will box them and hold on-station for possible future use on the green car, christened "Spruce Bruce" by my daughter. Had planned to renew both drive belts with stock-on-hand...but have misplaced my $15 "Burroughs Guage" somewhere in the bowels of my shop...so I reckon I'll have to do a general clean-up til it surfaces and then fit the new belts. |
I wish I could find a 15 dollar Borroughs gauge!
Agreed on using the 3M emblem tape as an alternative on the 3rd light repair. Using that tape is on my list to try next if the rear view mirror adhesive doesn't hold up. That tape is amazing. Read up on it; it "flows" into the material it is attached to over several hours at a microscopic level, and the industrial uses it has been applied to such as fitting high-rise building windows is surprising. It really is amazing stuff.
I have one of those "click" belt tension gauges, which seems to work well enough. They are dirt cheap. . |
Yeah, Al, that's what I've misplaced....Littlelic, I teasingly refer to it as my "Burroughs" gauge.
Al, you remind me why I still have that mirror cement: Purchased it to fit a Homelink mirror to the lad's Tundra, but had the 3M, and it looked so much easier, we stuck it on with that. Held up fine for nearly a year til one of his schoolmates rear-ended him at a stoplight, totaling the truck. As added bonus, we were able to cut it off, bracket and all, and refit the original to its bracket, still fitted to the windshield before surrendering the vehicle to insurance. |
My x300 has had some welding done to the nearside front inner sill , a drop test on it's alternator ( fine ) and now working on failed rear brake lights , looking at the ECM in boot as possible cause .. all this today and tomorrow , before our other x300 goes in for a touch up on it's bodywork and rear axle leak to be sorted .. going to be busy for day's I think .. pauljag
New A/C Belt, Tires Rotated and Balanced. At which point leaking Rack and Pinion and Power steering pump was found. Already knew the return line from the reservoir had small leak and was going to have that replaced. Also front wheel bearings shot and rear pads at 5%, rotors were too thin to machine again so new rotors new front bearings and rear pads installed. Waiting for the Rack and Pinion to ship (surprisingly cheap) now to source a power steering pump that is in stock that can ship now vs having to send a core in to get rebuilt. Any tips for that? All potential buyer is going to get quite a bargain with all these new repairs :)
Originally Posted by pauljag
(Post 1400912)
Hello again,a few updates from the past two weeks,the good and bad.
Replaced the alternator 4 times,now have it figured out it is easier to buy the ingiter and voltage regulator and brushes myself,seems it is the same as a 90s dodge caravan so on a diy it can be done at about $60. Replaced upper shock bushings in the rear passenger side,took about an hour but need to take it apart again because the upper spring cushion was trashed and I did not have a replacement one,so for the drivers side I ordered the bushings and the cushion for both sides. Picked up from the junk yard,a replacement rear view mirror,a replacement passenger front interior door handle but the PO swedged the cable to the other one so now I need to get the cable,the drivers side exterior door handle assembly all for $50 But it is 3 weeks later and they still have not pulled my other parts that I paid for back then. New tires but the installers lost the center cap on one rim and at first it was my fault according to them for what ever reason,so I gave them a reason to believe it was not my fault. Temporarily hung a set of cheap $7 rear brake pads,until I finish the rest of the mechanical then I will up grade properly. Charged the A/C but it only gets cold for the driver and not any of the other vents but they all blow air. Changed both headlight assemblies,now when I turn the parking lights on the left headlight also comes on.Fix one thing and something else goes funny in typical Jag fashion.Never has had front running lights. Re-soldered and taped up the broken wires at the trunk (boot) could not for the life of me find my shrink wrap which would have been ideal,until two hours after I had finished so I get to do that all over again. I still drive this car everyday. Went to clean the ISC and one of the bolts snapped off,so that project was shelved and sooner or later I am going to have to tackle the rough idle aspect. On a side note the ISC looks like a mid 80s ford 5.0 ISC ,I am going to try one and see if I can match the specs if possible their price is half of the replacement one. This week I get to install the front lower shock bushings which are no longer there,they are the same as the control arm bushings? But different price. The upper sub-frame mount,drives side is busted and sounds really nice going over the RR tracks. The rear upper shock bushings AND spring cushions,windshield wiper interior control,it is a bit of a pia to stick a toothpick in the relay when it is raining to get wipers. Got the oil change and they tried charging me $10 extra for the oil filter because it was a Jaguar.I used to own quick lubes in the 90s,I know better then that. But here is the thing,I know that this is a 18 year old car and none of the above bothers me in the least it is just a part of life. The kicker is I bought this car 3 weeks ago and it had no cat on the hood (bonnet) which I fully understand,they get lost or stolen or maybe even just fell off,it happens. So I am browsing the want adds still looking for the evasive red XJR and what do I see? Ha,a replacement cat at the low price of $65,I look at the contact number and low and behold it is the person that sold me the car,what kind of person removes the hood ornament before selling the car then resells it. I think he should be banned from looking at,thinking about,touching or even dreaming about a Jaguar for the rest of his life and forced to drive a AMC Pacer with busted out side windows and black trash bags taped in their place for the rest of his life. |
Replaced all four speakers today. What a difference, in with the bass, out with the crackling. Replaced them with 6.5 inch three way Pioneer coaxial speakers. The tweeters cleared the outer grill but I still had to make a spacer since I didn't want the rubber surround of the speaker pressed up against the door panel cutout.
I have a new headunit but I ordered an autoleads jaguar to iso harness and iso to Pioneer harness and they haven't come in yet. That will be a job for next weekend. https://cimg9.ibsrv.net/gimg/www.jag...ee2fe915b4.jpg |
Put the head unit in yesterday. Was surprised to see the factory unit was only 20 watts per channel. Decided to use the fascia to bring it out rather than having it sit in farther.
The head unit came with a microphone for Bluetooth calling and I decided to hide it in the air vent. I just didn't want it showing. Although the downside is I can't close the door to cut the air off the left vent. If you have the blower speed lower than half you can't hear the wind blowing past the mic, but high speed it sounds pretty bad. But it is what it is. https://cimg1.ibsrv.net/gimg/www.jag...e51f09bfc6.jpg |
Originally Posted by Scarecrow
(Post 1416112)
The head unit came with a microphone for Bluetooth calling and I decided to hide it in the air vent. I just didn't want it showing. Although the downside is I can't close the door to cut the air off the left vent. If you have the blower speed lower than half you can't hear the wind blowing past the mic, but high speed it sounds pretty bad. But it is what it is. I love the stock look of the alpine unit. I would really love to be able to keep that look while swapping out the internals with something a lot better, but I'm not even sure if that's possible. I will be fitting the same or similar speakers as you, though. Did they require any modification to fit? It wasn't today, exactly, but I spent days sorting out my suspension--you can't blame me, it was my first attempt at anything slightly challenging on a car. I replaced the lower ball joints, tie rod ends, brake pads, and fitted four new shocks. The shocks are Sensen and I picked them up on a whim because, hell, it was 100 bucks for all 4. They make the car handle great but the ride quality has definitely diminished a bit. The rear shocks were original and blown, and the fronts were seized KYBs which were sporadically too firm. I'll be getting Konis for the front, and possibly for the back, but I really don't want to have to do the rear shocks again... I'm confident I could do it in a few hours now, but after spending hours trying to find out why the seat wouldn't come out (what do you know... studs!) and resorting to a pry bar and some careful maneuvering, I'm a little ticked off at the thought of the job. I had to cut out the old shocks because they were rust welded onto the lower bolt. What was lost in the process: -lower shock bolts (temporarily have them secured with some run of the mill grade 3s) -rear passenger-side ABS sensor, where when I removed it the sensor remained and the + - plug came out and refused to ever work again -front passenger-side sway bar link bushing--it won't stay seated any longer, and I have it secured with a washer and lock nut, but it loves to clunk around at low speeds and mess with my steering when there's G force involved I just ordered two new sway bar links, sway bar bushings, 4 upper control arm bushings, 2 rear control arm bushings, and a replacement antenna (10 bucks, if you can believe that!). I look forward to finally getting this out of the way. I'm hoping it restores some ride quality. If not, I'll get the Konis ASAP. I've heard they're very comfortable. Still on the to-do list: -fix memory potentiometers (thanks JapThug!) -fit miscellaneous parts including missing sunroof trim -continue draining and filling transmission, and replace the filter because I couldn't get the fill tube bolt off last time -all the suspension pieces above -when everything's said and done, getting soft new tires and an alignment, as I've been adjusting the tie rods myself and there's no way it's correct--I also suspect some crabbing from the rear toe being off -fit an Andy bracket which I just ordered! I know this isn't a journal... but it feels good to get it out in text instead of confusing everyone I know in person. :o |
