What effect does an unplugged knock sensor have?
Old May 13, 2018 | 01:51 PM
Jagboi64's Avatar
Default What effect does an unplugged knock sensor have?
I bought a rusty 95 XJR as donor for the engine and it never seemed to have the power a 300hp car should - it never seemed as fast as my 94 6.0 V12 XJS for example.
Now that I have the engine out and am looking closer at it, I noticed the front knock sensor wiring was not plugged in. It never had a code or MIL light on, so will it have much effect on power? The manual says that it shroud have thrown a code, but didn't say what effect no knock sensor would have.
I'm wondering if I will need to dig deeper once I have the engine installed in my project car.
Old May 13, 2018 | 02:23 PM
Lady Penelope's Avatar
From what I understand 95 was very early in the OBD 2 codes from being shown and refined . This is different then the engine regulation that looks at this signal and retards the spark timing as how it is used .
Recommend just plug it in and let it go . There is a youtube video on how to test them .
While your in the area and up the air might consider replacing the gaskets on the coolant water rails , oil filter housing gaskets , and oil pressure sender . There was a 95 TSB on changing the camshaft over from a 110 degree overlap to a 14 degree overlap for better idle quality and if the mod has been done there is a marking somewhere in the TSB :
http://www.jagrepair.com/images/TSB/...%20Changes.pdf
Looks like normally aspirated engines only
Save the MAF and manifolds from the original engine .
Old May 16, 2018 | 06:48 AM
XJRengineer's Avatar
Diagnosing a disconnected knock sensor was one of the hardest electrical faults to diagnose. The impendence of the device is very high and the signal level is very small. However, I can't explain why a fault code was not logged. If a fault code was detected, I think the software retarded the ignition timing as knock could no longer be detected. After 24 years, I can't remember precisely how the knock diagnostic Failure Mode Effects Management (FMEM) software worked. if it was active, then that might explain an apparent reduction in engine performance.
car5car
Feb 7, 2016 12:51 PM
frozennorth
Nov 7, 2012 11:09 PM
KidRock'n
Nov 22, 2010 02:10 AM
cooke
Sep 11, 2010 04:25 AM
