What is this switch and how to remove it
Old Oct 5, 2022 | 12:07 PM
  #41
Parker 7's Avatar
rubber plug?
Old Oct 5, 2022 | 12:14 PM
  #42
Parker 7's Avatar
Notice the elongated mounting holes to keep track of when reinstalling the switch back on the transmission
Old Oct 6, 2022 | 06:10 PM
  #43
sturner's Avatar
Ok 2 things,,, With key in run pos the bottom 2 tabs have 12v to them, when i used a jumper wire to all other tabs the car starts, 2nd how do I get the lever off, I tried 1/4 drive ratchet but I was afraid I was going to break it
Old Oct 6, 2022 | 06:41 PM
  #44
sturner's Avatar
Ok figured out how to get it off
Old Oct 6, 2022 | 06:55 PM
  #45
sturner's Avatar
Is that suppose to be bridged ??
Old Oct 6, 2022 | 10:59 PM
  #46
Parker 7's Avatar
No bridge
The contact strips on the bottom 2 are the same so it's a redundant feature in case one " lifts off " of contact , this increases the reliability
Your focus is pin 6 ( Green / Orange wire ) and 7 ( Red / Orange ) for the stater relay command ground path through the switch
So you have 6 soldier points for 6 pins on the top of the pic
The rotary pivot probably has 2 contact brushes to bring the total to 8 pins
Probably the best you can do with the pivot point brushes is an alcohol wash and not a solvent that may damage or warp the fine plastics in the pivot point , this is probably your fluid intrusion area and not the O - ring seal
Old Oct 8, 2022 | 11:35 AM
  #47
sturner's Avatar
Hope you can make out what I'm trying to say here
Old Oct 8, 2022 | 11:43 AM
  #48
Parker 7's Avatar
Looks like the 5 pin is not used , pin map backwards ?
Pin 1 should go to car frame ground < and this 1 pin should be in the corner of the connector as a orientation
  #49
sturner's Avatar
With lever on #1, #5, #6 have 12v in Park, Move shifter out of P #6 got to zero but in neutral #6 has 12v again so I believe rotary switch is working
Old Oct 8, 2022 | 11:46 AM
  #50
Parker 7's Avatar
Your 6 volt readings are valid as this seems to be the feeling voltage on the breakout sheet
Editing
Old Oct 8, 2022 | 12:01 PM
  #51
sturner's Avatar
No the map is correct, I'm not going by the connector I'm going by the solder points on the plate,,, So what would be next? BPM ? The TPM ?
Old Oct 8, 2022 | 12:05 PM
  #52
Parker 7's Avatar
Editing above and will take some time to place value in the vertical column
Multi tasking
Old Oct 8, 2022 | 12:48 PM
  #53
Parker 7's Avatar
There is a BPM reset for your US model
But you did say by jumper Ing the switch you got starter rotation ?
Old Oct 8, 2022 | 03:14 PM
  #54
sturner's Avatar
Yes car started
Old Oct 10, 2022 | 12:47 PM
  #55
sturner's Avatar
[QUOTE=Parker 7;2574744]There is a BPM reset for your US model
Are you referring to the hard reset by holding battery cables together ?? If so I already tried that, if not wha is it please
Old Oct 10, 2022 | 04:19 PM
  #56
Parker 7's Avatar
Yes , I found by clamping them together over night the better
someone used Tywrasp and I use a battery jumper cable ( overkill )
Must put something over the battery post to not make contact
I was just at a salvage yard so there are fresh pickings on a X300 that just came in like a BPM or a rotary switch
Old Oct 11, 2022 | 01:29 PM
  #57
sturner's Avatar
Originally Posted by Parker 7
So l;ets track it down in a different path being the key lock solenoid
Editing
The Body Processor Module is continuing to provide a ground on the Red / White color wire
Ok , So if I'm reading this right, The Brake switch & Not In Park switch both send a signal to the BPM, Which then sends signal to Key lock relay & key lock solenoid ,Also Gearshift interlock relay & gearshift interlock solenoid, Either circuit will prevent crank and give me the lights?
Old Oct 11, 2022 | 02:10 PM
  #58
Parker 7's Avatar
The BPM is looking for all agreements / enables on the left side and then provides a command ground for the 2 relays for the interlock solenoids
Thinking on your last sentence in how this ties into the starter solenoid relay but the agreements / enables are a different set of devices in the starter solenoid circuit
So this raises the question of what goes on inside the box which you may not ihave information about clouding up what information you do have
In the end the BPM must provide a command ground for the starter solenoid relay so a test light bulb that you can see from the cabin by yourself may be helpful , this test bulb at the starter solenoid relay will be confirming your rotary position switch path is good or not as 1 of 2 possibilities , either the BPM is not providing the command ground, or the rotary position switch is not enabling a ground path
Have you swapped this starter solenoid relay as it may be marginaly failed in a manor and not totally ?
I think you changed the starter but someone recently did find a starter assembly connection loose
The question is if the BPM is being powered by the fuse in the trunk ? This involves a connector to learn it,'s precaution about before tinkering with the connector
Old Oct 11, 2022 | 02:36 PM
  #59
sturner's Avatar
I switch and replaced starter relay,I just checked Key lock relay and gearshift interlock relay both have 12v on circuits 1 & 3,Weird thing I just discovered is I cannot remove the key in park position but I can in every other position,,Fuse in trunk for BPM is good
Old Oct 11, 2022 | 03:09 PM
  #60
sturner's Avatar
It seems something is making this car think its in gear it seems to me
