Wire colors at luggage compartment hinge?
Old Sep 11, 2012 | 07:32 PM
Joe Reed's Avatar
Default Wire colors at luggage compartment hinge?
After searching this forum for info I decided to try to fix my inoperable luggage compartment lamps. Upon inspecting the wires at the hinge I discovered two severed wires. I repaired them, hoping they were the culprits....they weren't!
Anyone know what the yellow/orange wire is for?
How about the black/white wire?
Those are the ones I repaired and I can't think of anything else that wasn't working that those might affect. I searched the wiring diagrams and only found a couple of those color wires - but neither of those appeared to be the ones I repaired.
Keep in mind that my MGB wiring diagram covers one page....and I have most of those (few) colors used committed to memory! The XJ6 is a whole different story!!!
Also, where is the switch for those lamps, and how is it accessed? I'll see if the switch is the problem next....
Old Sep 12, 2012 | 06:46 AM
mgb4tim's Avatar
There's not that many wires that can be run on 4 fuses.
Old Sep 12, 2012 | 01:12 PM
Joe Reed's Avatar
The Jag has about as many fuse BOXES as the MG does FUSES!
trosty
Jan 8, 2016 06:43 PM
Bc xj
Sep 17, 2015 06:34 PM
pjanca
Sep 16, 2015 08:07 PM
Mamuka Darakhvelidze
Sep 13, 2015 09:35 AM
jaguarbill
Sep 5, 2015 11:43 AM
