X300 3.2 front coil spring replacement
Old Jan 21, 2025 | 01:40 PM
sam1977's Avatar
Default X300 3.2 front coil spring replacement
Evening all
I did my rear shocks and springs 3-4 years ago as the car was sitting low at the rear. The foam doughnut thing at the top was basically disintegrated so renewed everything. The front is now very low and it scrapes over speed humps. How hard is it to change the front springs and the top mount rubber/foam etc. as I did on the rear? Obviously shocks as well whilst I am in there.
Sam.
Old Jan 28, 2025 | 10:32 AM
cdma's Avatar
If you don’t have a spring compressor, this task could be extremely difficult and dangerous. I recommend checking the tool lending section on JCNA.com or reaching out to someone on this forum for a homemade solution. However, even with a homemade tool, without the proper spring compressor, there’s always a risk of a life-threatening scenario. Proceed with caution.
Old Jan 28, 2025 | 10:42 AM
PBoudr's Avatar
Old Jan 28, 2025 | 04:22 PM
watto700's Avatar
G'day Sam,
If you search the X300 forum for 'spring compressor' you will get over 50 hits and find all the information you need.
Look at the top of the threads and you will find a "Search this Forum" prompt.
Cheers,
Jeff.
Old Jan 28, 2025 | 10:32 PM
Parker 7's Avatar
Here in the US the common auto parts stores have dedicated tool kits you can barrow which in my case for a non - Jaguar came in 2 different spring compression tool styles
Very rugged built and safe
Better safe than sorry and don't trust your judgement on what is OK
This is an example of their loaner program
autozone.com/searchresult?searchText=loaner tools
92/93 XJS
Jan 17, 2023 04:43 PM
92/93 XJS
Jan 14, 2023 05:13 PM
retroren
Apr 29, 2021 11:45 AM
alckc
Feb 11, 2016 06:08 PM
sirlasc
Dec 10, 2010 05:22 PM
